HA 0.113 - HomeKit-accessoire: eufy HomeBase2-1614
I upgraded to 0.113 yesterday and after the installation completed, HA notified me about a new device in my network. It recognized my Eufy HomeBase 2 as a HomeKit accessoire that I use together with my doorbell.
When I tried to setup my device, I got the message that it’s already attached to a different system and that I should unlink it first. However, it’s not linked at all.
Anyone else here with a HomeBase 2 and having this issue as well?
yes i have this same issue… I don’t understand because i did never configure the doorbell or homebase in any Homekit setup…
Since the device can speak HomeKit, Home Assistant is offering to connect with the device locally (no cloud) with the HomeKit protocol.
Same here, thinking of reseting the home base 2 and see if anything changes!
Hmmm ok. So I guess it’s detected in some other way then.
Please post the result here. :slight_smile: Really curious if you can get it to work.
Did this work for anyone ?
I see this too…
What if u configure, does the doorbell work?
Or only cams?
I dont have anything from homekit though
Any updates on this topic? Had the same after updating. Clicking on configure had the homebase say something and then then the integration was gone out of home assistant…
I have HA on virtual machine (windows) and android mobile, I have the eufy homebase 2 and I only have a identify button and I can no longer use my keypad, motion sensor, or door sensors now not setting up my 2k pan and tilt because the RTSP method works pre good so, I have no laptop bluetooth working and I beleave that’s the reason why ( thought they would still link to homebase) but no, the homebase just keeps saying can’t setup device when setting up keypad or sensors to homebase via pressing the sync button on both devices can anyone help? (No configuration.yaml edit has been done for eufy) tried that didn’t work this is the closest I have got to eufy working with HA 1/11/2022 10:43pm +10.00 Eastern standard time (Australia)
It needs to be factory reset it can not be linked to eufy app and homekit at the same time that’s where mine has started working (just) not very good but working I recommend a RTSP method if possible to HA
