Hi, I’ve upgraded my HA Core to 0.115.1 and I have problem with integration with my bluetooth device (EQ3 termostats). I cannot instal bluepy library.
Here is my log:
Building wheels for collected packages: bluepy
Running setup.py bdist_wheel for bluepy ... error
Complete output from command /srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-5h09mtw8/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-knketgmj --python-tag cp37:
running bdist_wheel
running build
running build_py
Working dir is /tmp/pip-install-5h09mtw8/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
Failed to compile bluepy-helper. Exiting install.
Command was 'make -C bluepy -j1' in /tmp/pip-install-5h09mtw8/bluepy
Return code was 2
Output was:
b"make: Entering directory '/tmp/pip-install-5h09mtw8/bluepy/bluepy'\ntar xzf bluez-src.tgz\ntouch ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containing `glib-2.0.pc'\nto the PKG_CONFIG_PATH environment variable\nNo package 'glib-2.0' found\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containing `glib-2.0.pc'\nto the PKG_CONFIG_PATH environment variable\nNo package 'glib-2.0' found\ncc -L. -g -Wall -Os -DHAVE_CONFIG_H -I./bluez-5.47/attrib -I./bluez-5.47 -I./bluez-5.47/lib -I./bluez-5.47/src -I./bluez-5.47/gdbus -I./bluez-5.47/btio -I./bluez-5.47/sys -o bluepy-helper bluepy-helper.c ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c \nbluepy-helper.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/attrib/att.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/attrib/gatt.c:32:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/attrib/gattrib.c:34:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/attrib/utils.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/btio/btio.c:37:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/src/log.c:38:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/src/shared/io-glib.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\n./bluez-5.47/src/shared/timeout-glib.c:22:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\nmake: *** [Makefile:30: bluepy-helper] Error 1\nmake: Leaving directory '/tmp/pip-install-5h09mtw8/bluepy/bluepy'\n"
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Running setup.py install for bluepy ... error
Complete output from command /srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-5h09mtw8/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-sh93324l/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/bluepy:
running install
running build
running build_py
Return code was 2
Output was:
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-5h09mtw8/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-sh93324l/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/bluepy" failed with error code 1 in /tmp/pip-install-5h09mtw8/bluepy/
