A clean install of 0.85 on R-Pi 4 and have now added most of the add-in packages I want such as MQQT, Node-RED, DuckDNS, SSH and TasmoAdmin and all the basics seem to work. Have not added any sensors, lights, switches, automations, etc etc. although HA has found a few things automatically. Just the basic build with the add-ins listed.
But looking at the log I have this error:
[Info] Start install HomeAssistant latest
You are using pip version 18.0, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
[Info] Install done, check config now
[Error] Wrong config found!
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /tmp/config
Failed config
sensor.systemmonitor:
- Invalid config for [sensor.systemmonitor]: value is not allowed for dictionary value @ data['resources'][3]['type']. Got 'since_last_boot'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.systemmonitor/
- platform: systemmonitor
resources: [source /tmp/config/sensors.yaml:50]
- type: memory_use_percent
- type: processor_use
- type: last_boot
- type: since_last_boot
Successful config (partial)
Are these items something to ignore or should I be worried as I have not yet added systemmonitor or anything along these lines yet?
