I’m using HASS more than a year now, and I’m trying to be a faithful upgrader. In our household, we have iPads (version 2)
Since the upgrade to HA 0.96.5 the “Overview” screen no longer works in the iOS apps (only) for our iPads (2). (Note: the same problem occurs on in the iOS 1.5.1 app)
The other views (“Map”, “Logbook”, etc…) are functioning normally, so it only concerns the “Overview” view…
I also use a few older iPads, 2nd and 3rd gen running iOs 9.X
Lovelace doesn;t really work because it uses newer JS version while the iPad is stuck with the older version.
The ‘states’ UI works far better for me on the older iPad, but I have mostly moved away from this and am now using Tileboard UI which works great even with older JS versions
