HA 11.5 Dashboard with LQI?
Hello, I’m a HA 11.5 noob and I’ve setup my first temperature zigbee sensor.
I’ve added some nice entities to a Dashboard card like Temperature, Humidity and Battery.
However, I would also like to add the LQI. I tried from the Dashboard cards to add an entity, but see no option for the LQI entity?
I do see the temperature sensor LQI in Add-Ons → OPEN WEB UI → LQI → 180.
Go to the device page of your sensor and enable the LQI sensor. They are disabled by default.
Screenshot 2024-03-04 at 22-57-47 Settings – Home Assistant
Untitled
Wait 30 seconds. You should then be able to add it to your dashboard.
Thank you, that really worked!
