Fresh installation of Home Assistant (DIY with Raspberry Pi)
Factory reset of my Aeotec Z-Stick Gen5+
After plugging in it will be discovered in integrations
After confirming the dialog without providing any keys
the Pi will become unresponsive.
What‘s wrong? Any hints?
Many thanks in advance!
Z-Wave JS LOG:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[15:12:31] INFO: Both ‘network_key’ and ‘s0_legacy_key’ are set and match. All ok.
Home Assistant Core LOG:
Ended unfinished session (id=12 from 2024-05-26 07:34:02.908197)
15:14:25 – (WARNING) Recorder
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
Thanks for your feedback! Let me try to provide helpful detail:
After ignoring the security keys and confirming the setup the popup window ‚The Z-Wave JS add-on installation has started (can take several minutes)‘ appears again.
After a few minutes the web browser won‘t get any answers from HA. After appr. 15-20 minutes HA will restart with the Z-Wave JS add-on stopped.
It is unusual of course for HA to restart itself. I’m wondering if your system maybe memory or disk space limited (I don’t really know). Anyway, when you Start the ZWaveJS AddOn, then goto UI->System->Logs choose ZWaveJS from upper right pull down to see if you get any indication from it, and also check Supervisor logs as well as Home Assistant Core to see if there are any issues with the ZWave Integration.
Hi Tommy, thanks for your help! Here is my ZWaveJS Log:
2024-06-08T15:04:04.162Z CNTRLR Enabling TX status report successful...
2024-06-08T15:04:04.163Z CNTRLR finding SUC...
2024-06-08T15:04:04.188Z CNTRLR No SUC present in the network
2024-06-08T15:04:04.189Z CNTRLR There is no SUC/SIS in the network - promoting ourselves...
2024-06-08T15:04:04.225Z CNTRLR Promotion to SUC/SIS succeeded.
2024-06-08T15:04:04.227Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2024-06-08T15:04:04.252Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
0 ms
2024-06-08T15:04:04.442Z CNTRLR Interview completed
Starting server on <all interfaces>:3000
2024-06-08T15:04:04.733Z CNTRLR [Node 001] Beginning interview - last completed stage: None
2024-06-08T15:04:04.751Z CNTRLR [Node 001] new node, doing a full interview...
2024-06-08T15:04:04.759Z CNTRLR » [Node 001] querying protocol info...
ZwaveJS server listening on <all interfaces>:3000
2024-06-08T15:04:05.273Z CNTRLR « [Node 001] received response for protocol info:
basic device class: Static Controller
generic device class: Static Controller
specific device class: PC Controller
node type: Controller
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2024-06-08T15:04:05.277Z CNTRLR [Node 001] Interview stage completed: ProtocolInfo
2024-06-08T15:04:05.374Z CNTRLR [Node 001] Embedded device config loaded
2024-06-08T15:04:05.376Z CNTRLR [Node 001] Interview stage completed: OverwriteConfig
2024-06-08T15:04:05.630Z CNTRLR [Node 001] Interview completed
2024-06-08T15:04:05.635Z CNTRLR [Node 001] The node is ready to be used
2024-06-08T15:04:05.638Z CNTRLR All nodes are ready to be used
2024-06-08T15:04:05.647Z CNTRLR [Node 001] The node is alive.
2024-06-08T15:04:05.652Z CNTRLR Interviewing nodes and/or determining their status:
s6-rc: info: service legacy-services: stopping
Shutting down
Closing server...
Server closed
[15:24:26] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[17:34:19] INFO: No s0_legacy_key is set, generating one...
[17:34:23] INFO: No 'network_key' detected, setting it to 's0_legacy_key' for backwards compatibility
[17:34:26] INFO: No s2_access_control_key is set, generating one...
[17:34:30] INFO: No s2_authenticated_key is set, generating one...
[17:34:34] INFO: No s2_unauthenticated_key is set, generating one...
[17:34:37] INFO: No lr_s2_access_control_key is set, generating one...
[17:34:41] INFO: No lr_s2_authenticated_key is set, generating one...
[17:34:43] INFO: Flushing config to disk due to creation of new key(s)...
[17:34:49] INFO: Soft-reset set to automatic
[17:34:49] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[17:38:24] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[17:38:32] INFO: Soft-reset set to automatic
[17:38:32] INFO: Virtual Machine not detected, enabling soft-reset
[17:48:26] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[17:48:35] INFO: Soft-reset set to automatic
[17:48:35] INFO: Virtual Machine not detected, enabling soft-reset
Ended unfinished session (id=11 from 2024-06-08 15:28:16.201509)
17:56:41 – (WARNUNG) Recorder
The logs indicate that it sees the Z-Stick and seems to be OK with it at the beginning, then it tries to interview additional nodes and that is where it crashes. This is very unusual, and I don’t have knowledge at this point to know what is going on. My only suggestion is to factory reset the Z-Stick and if you still see this problem, post a question along with the logs to ZwaveJS GitHub and see if someone there can help.
