I upgraded friom 2023.4.4 to 2023.4.5 and OS 9.5 to 10.0 and now my Eufy switch does not work. In fact I cannot even restart HAS when I have the username/password for Eufy in my config file. Getting these error messages, any ideas where to start.
Home Assistant Core
[1568770656] The system cannot restart because the configuration is not valid: Component error: eufy - Exception importing homeassistant.components.eufy
5:30:45 PM – (ERROR) Home Assistant WebSocket API
5:30:45 PM – (ERROR) Home Assistant Supervisor
Unexpected exception importing component homeassistant.components.eufy
5:30:45 PM – (ERROR) components/eufy/init.py - message first occurred at 5:00:07 PM and shows up 3 times
[1568770656] Cannot quick reload all YAML configurations because the configuration is not valid: Component error: eufy - Exception importing homeassistant.components.eufy
5:29:57 PM – (ERROR) Home Assistant WebSocket API
The system cannot reload because the configuration is not valid: Component error: eufy - Exception importing homeassistant.components.eufy
5:29:57 PM – (ERROR) Home Assistant Core Integration
I have the same problem in 2023.4.5 and OS10.0:
2023-04-20 10:25:10.799 ERROR (MainThread) [homeassistant.components.homeassistant] The system cannot reload because the configuration is not valid: Component error: eufy - Exception importing homeassistant.components.eufy
2023-04-20 10:25:10.815 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140114828910672] Cannot quick reload all YAML configurations because the configuration is not valid: Component error: eufy - Exception importing homeassistant.components.eufy
Dang, I was afraid of that. I am not going to upgrade until Eufy is resolved. But I am anxious to try the new voice stuff. I see there is a Github issue #91614 that was closed because it was fixed by #92173 that has not really moved anywhere. Status says it is “merged”. there has not been any activity for a few days, I don’t have a clue as to how these fixes get put into Home Assistant releases. I see there is already a 2023.5.1 release but I don’t see any references to #91614 or #92173
