Hi All,
After HA 2024.1.0 update I see those errors:
2024-01-04 08:56:43.624 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID 2C:F4:32:4B:36:F0-switch-bathroom___safe_mode already exists - ignoring switch.bathroom_safe_mode
2024-01-04 08:56:43.717 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID DC:4F:22:7C:2E:5D-switch-doorbell___safe_mode already exists - ignoring switch.doorbell_safe_mode
2024-01-04 08:56:43.776 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID DC:4F:22:7C:3C:55-switch-diningroom___safe_mode already exists - ignoring switch.diningroom_safe_mode
2024-01-04 08:56:43.826 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID 2C:F4:32:65:40:4D-switch-diningtable___safe_mode already exists - ignoring switch.diningtable_safe_mode
2024-01-04 08:56:43.839 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID 2C:F4:32:65:20:9D-switch-livingroom___safe_mode already exists - ignoring switch.livingroom_safe_mode
2024-01-04 08:56:43.951 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID BC:DD:C2:B3:9E:CE-switch-hallway___safe_mode already exists - ignoring switch.hallway_safe_mode
2024-01-04 08:56:45.412 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID DC:4F:22:7C:35:79-switch-toilet___safe_mode already exists - ignoring switch.toilet_safe_mode
2024-01-04 08:56:57.648 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID 48:3F:DA:92:63:19-switch-kitchen___safe_mode already exists - ignoring switch.kitchen_safe_mode
Every time I restart HA I get this error. IS there something I can do about this?
Example of YAML file ESPhome (BELOW this the package YAML content):
# Below all fixed settings for bedroom PCB
substitutions:
devicename: meek-bedroom
friendly: Bedroom
ip: 192.168.100.203
touch_power: GPIO16 # (D0)
neopixel: GPIO02 #(D4)
gpio_touch1: GPIO12 # (D6)
gpio_relay1: GPIO05 # (D1)
# Everything below can be copy/paste without problem
packages:
device_base: !include defaults/for_all_devices.yaml
esphome:
on_boot:
priority: 600
then:
- switch.turn_on: touch_power
esp8266:
board: esp01_1m
restore_from_flash: true
wifi:
ssid: !secret wifi_ssid
reboot_timeout: 0s
fast_connect: true
manual_ip:
static_ip: ${ip}
gateway: 192.168.100.1
subnet: 255.255.255.0
dns1: 192.168.100.1
ap:
ssid: ${devicename}
password: !secret password
channel: 4
light:
- platform: neopixelbus
default_transition_length: 0s
type: GRB
variant: 800KBPS
pin: ${neopixel}
num_leds: 1
name: "${friendly} - Neopixel"
restore_mode: RESTORE_DEFAULT_OFF
effects:
- strobe:
- addressable_rainbow:
- addressable_color_wipe:
- addressable_scan:
- addressable_twinkle:
- addressable_random_twinkle:
- addressable_flicker:
- pulse:
update_interval: 1s
- addressable_lambda:
update_interval: 100ms
lambda:
static int state = 0;
if (initial_run){
state = 0;
it.all() = ESPColor(0,255,0);
} else {
it.all() = ESPColor(255, 0, 127);
if(state==0){
int i = rand() % it.size();
it[i] = ESPColor(0,255,0);
state += 1;
} else {
state += 1;
state = state % 10;
switch:
- platform: gpio
pin: ${touch_power}
name: "${friendly} - Touch 1 power"
icon: mdi:electric-switch
name: "${friendly} - Light Switch"
optimistic: true
icon: mdi:nintendo-switch
name: "${friendly} - Switch longpress"
optimistic: true
- platform: gpio
pin: ${gpio_relay1}
name: "${friendly} - Relay"
binary_sensor:
- platform: gpio
pin: ${gpio_touch1}
name: "${friendly} - Touch"
icon: mdi:gesture-tap-button
on_click:
- min_length: 10ms
max_length: 500ms
then:
- switch.toggle: switch1
- min_length: 1000ms
max_length: 2000ms
then:
- switch.toggle: switch_longpress1
api:
encryption:
key: !secret api_key
reboot_timeout: 15min
time:
- platform: homeassistant
captive_portal:
web_server:
port: 80
preferences:
flash_write_interval: 1min
logger:
level: INFO
ota:
safe_mode: true
button:
- platform: factory_reset
name: "${friendly} - Reset"
switch:
- platform: safe_mode
name: "${friendly} - safe mode"
- platform: wifi_signal
name: "${friendly} - Wifi Signal"
update_interval: 5min
- platform: uptime
name: "${friendly} - Uptime"
text_sensor:
- platform: wifi_info
ip_address:
name: "${friendly} - IP"
icon: mdi:lan
ssid:
name: "${friendly} - SSID"
icon: mdi:lan
bssid:
name: "${friendly} - BSSID"
icon: mdi:lan
mac_address:
name: "${friendly} - MAC"
icon: mdi:lan
- platform: version
name: "${friendly} - Version"
hide_timestamp: true
