Hi All,
Since HA 2024.1.0 and 2024.1.1 I see this error. With 2023.12.5 or below no issues. What can this be? A issue in platform: template? (see below the error message)
2024-01-05 18:52:15.793 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({% set speed = {'off': 0, 'low': 33, 'medium': 66, 'high': 100} %} {{speed [states('sensor.fan_speed')] | float(0) }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 567, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2305, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1984, in forgiving_float_filter
return float(value)
jinja2.exceptions.UndefinedError: 'dict object' has no attribute 'unavailable'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 693, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 569, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'dict object' has no attribute 'unavailable'
2024-01-05 18:52:15.796 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('UndefinedError: 'dict object' has no attribute 'unavailable'') while processing template 'Template<template=({% set speed = {'off': 0, 'low': 33, 'medium': 66, 'high': 100} %} {{speed [states('sensor.fan_speed')] | float(0) }}) renders=4>' for attribute '_percentage' in entity 'fan.mechanical_ventilation'
Only what I had all the time was this when I restarted HA:
2024-01-05 18:52:17.478 ERROR (MainThread) [pyhap.characteristic] SecuritySystemCurrentState: value=0 is an invalid value.
2024-01-05 18:52:17.479 ERROR (MainThread) [pyhap.characteristic] SecuritySystemTargetState: value=0 is an invalid value.
Template config:
fans:
mechanical_ventilation:
friendly_name: "Mechanische afzuiging"
value_template: >
{{ "off" if states('sensor.fan_speed') == 'off' else "on" }}
percentage_template: >
{{speed [states('sensor.fan_speed')] | int() }}
turn_on:
service: switch.turn_on
entity_id: switch.fan_high
turn_off:
entity_id: switch.fan_standby
set_percentage:
data_template:
entity_id: >
{% set id_mapp = {0: 'switch.fan_standby', 33:'switch.fan_low', 66:'switch.fan_medium', 100:'switch.fan_high'} %}
{{id_mapp[percentage]}}
speed_count: 2
