HA 24.10.1 Container - Alexa MP 4.13.3 - HA Hangs and Pi Crashes
Hoping someone can help me here without me having to reinstall everything.
So I’m running HA in a docker container on an RPi4 4GB with RaspberryPiOS Bullseye.
Everything has been running superbly until I installed AMP 4.13.3 straight after it came out. From then on things started to go badly. The UI would load but be unresponsive and then HA would crash. I somehow suspected AMP and removed the folder custom_components/alexa_media and rebooted.
This worked, in a way, as HA started and seemed ok, but from here I started to get nightly crashes. The OS itself would suddenly just die in the early hours and in the morning I’d notice that no automations were running, so would have to reboot the Pi.
Yesterday I bit the bullet and decided to install AMP 4.13.4, hoping that the fixes it contained would overwrite anything that still remained from AMP 4.13.3 in my HA install after my amateurish attempt to remove it. This seemed ok, but during the day I noticed free memory slowly reducing and HA memory increase to ~1.5gb.
This morning I woke up to no automations again, but this time the Pi itself hadn’t crashed. Bullseye decided to kill the HA process. Here’s a snippet of the journalctl log, apologies for the formatting it’s a straight copy/paste, not sure it will help anyone diagnose my issue: -
Oct 09 08:14:41 raspberrypi4 kernel: CPU: 0 PID: 1 Comm: systemd Tainted: G         C         6.1.21-v8+ #1642
Oct 09 08:14:41 raspberrypi4 kernel: Hardware name: Raspberry Pi 4 Model B Rev 1.1 (DT)
Oct 09 08:14:41 raspberrypi4 kernel: Call trace:
Oct 09 08:14:41 raspberrypi4 kernel:  dump_backtrace+0x120/0x130
Oct 09 08:14:41 raspberrypi4 kernel:  show_stack+0x20/0x30
Oct 09 08:14:41 raspberrypi4 kernel:  dump_stack_lvl+0x8c/0xb8
Oct 09 08:14:41 raspberrypi4 kernel:  dump_stack+0x18/0x34
Oct 09 08:14:41 raspberrypi4 kernel:  dump_header+0x4c/0x21c
Oct 09 08:14:41 raspberrypi4 kernel:  oom_kill_process+0x2a8/0x2b0
Oct 09 08:14:41 raspberrypi4 kernel:  out_of_memory+0xf0/0x350
Oct 09 08:14:41 raspberrypi4 kernel:  __alloc_pages_slowpath.constprop.158+0x7d4/0xbc0
Oct 09 08:14:41 raspberrypi4 kernel:  __alloc_pages+0x2a8/0x318
Oct 09 08:14:41 raspberrypi4 kernel:  __folio_alloc+0x1c/0x28
Oct 09 08:14:41 raspberrypi4 kernel:  __filemap_get_folio+0x214/0x5f0
Oct 09 08:14:41 raspberrypi4 kernel:  filemap_fault+0x644/0xc40
Oct 09 08:14:41 raspberrypi4 kernel:  __do_fault+0x44/0x170
Oct 09 08:14:41 raspberrypi4 kernel:  __handle_mm_fault+0x508/0x9c0
Oct 09 08:14:41 raspberrypi4 kernel:  handle_mm_fault+0x1c4/0x2e0
Oct 09 08:14:41 raspberrypi4 kernel:  do_page_fault+0x1f4/0x480
Oct 09 08:14:41 raspberrypi4 kernel:  do_translation_fault+0x54/0x70
Oct 09 08:14:41 raspberrypi4 kernel:  do_mem_abort+0x48/0x98
Oct 09 08:14:41 raspberrypi4 kernel:  el0_da+0x48/0xa0
Oct 09 08:14:41 raspberrypi4 kernel:  el0t_64_sync_handler+0x68/0xc0
Oct 09 08:14:41 raspberrypi4 kernel:  el0t_64_sync+0x18c/0x190
Oct 09 08:14:41 raspberrypi4 kernel: Mem-Info:
Oct 09 08:14:41 raspberrypi4 kernel: active_anon:476537 inactive_anon:382439 isolated_anon:0
Oct 09 08:14:41 raspberrypi4 kernel: Node 0 active_anon:1906148kB inactive_anon:1529756kB active_file:556kB inac
tive_file:1260kB unevictable:32kB isolated(anon):0kB isolated(file):0kB mapped:3840kB dirty:0kB writeback:0kB shmem:60k
B writeback_tmp:0kB kernel_stack:8992kB pagetables:24976kB sec_pagetables:0kB all_unreclaimable? no
Oct 09 08:14:41 raspberrypi4 kernel: DMA free:14772kB boost:0kB min:3104kB low:3880kB high:4656kB reserved_higha
tomic:0KB active_anon:438136kB inactive_anon:223084kB active_file:0kB inactive_file:508kB unevictable:0kB writepending:
0kB present:786432kB managed:702096kB mlocked:0kB bounce:0kB free_pcp:1064kB local_pcp:24kB free_cma:1568kB
Oct 09 08:14:41 raspberrypi4 kernel: lowmem_reserve[]: 0 2933 2933 2933
Oct 09 08:14:41 raspberrypi4 kernel: DMA32 free:13184kB boost:0kB min:13276kB low:16592kB high:19908kB reserved_
highatomic:0KB active_anon:1468012kB inactive_anon:1306672kB active_file:1336kB inactive_file:212kB unevictable:32kB wr
itepending:0kB present:3080192kB managed:3003436kB mlocked:32kB bounce:0kB free_pcp:2208kB local_pcp:492kB free_cma:0kB
Oct 09 08:14:41 raspberrypi4 kernel: lowmem_reserve[]: 0 0 0 0
Oct 09 08:14:41 raspberrypi4 kernel: DMA: 428*4kB (UMEC) 166*8kB (UMEC) 109*16kB (UMEC) 70*32kB (UMEC) 25*64kB (
UMEC) 12*128kB (UME) 7*256kB (UME) 2*512kB (UE) 2*1024kB (ME) 0*2048kB 0*4096kB = 15024kB
Oct 09 08:14:41 raspberrypi4 kernel: DMA32: 1199*4kB (UME) 478*8kB (UME) 182*16kB (UME) 68*32kB (UME) 3*64kB (U)
 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 13900kB
Oct 09 08:14:41 raspberrypi4 kernel: 8308 total pagecache pages
Oct 09 08:14:41 raspberrypi4 kernel: 7733 pages in swap cache
Oct 09 08:14:41 raspberrypi4 kernel: Free swap  = 88kB
Oct 09 08:14:41 raspberrypi4 kernel: Total swap = 1048572kB
Oct 09 08:14:41 raspberrypi4 kernel: 966656 pages RAM
Oct 09 08:14:41 raspberrypi4 kernel: 0 pages HighMem/MovableOnly
Oct 09 08:14:41 raspberrypi4 kernel: 40273 pages reserved
Oct 09 08:14:41 raspberrypi4 kernel: 131072 pages cma reserved
Oct 09 08:14:41 raspberrypi4 kernel: Tasks state (memory values in pages):
Oct 09 08:14:41 raspberrypi4 kernel: [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Oct 09 08:14:41 raspberrypi4 kernel: [    175]     0   175     5567       18    57344      664         -1000 systemd-udevd
Oct 09 08:14:41 raspberrypi4 kernel: [    434]   108   434     1795       74    40960       73             0 avahi-daemon
Oct 09 08:14:41 raspberrypi4 kernel: [    435]     0   435     1673       24    49152       40             0 cron
Oct 09 08:14:41 raspberrypi4 kernel: [    436]   104   436     2141      145    53248      160          -900 dbus-daemon
Oct 09 08:14:41 raspberrypi4 kernel: [    438]  1000   438   131840     2442   323584    10854             0 deCONZ
Oct 09 08:14:41 raspberrypi4 kernel: [    448]     0   448    58888        1    86016      584             0 polkitd
Oct 09 08:14:41 raspberrypi4 kernel: [    464]     0   464    55325      113    69632      255             0 rsyslogd
Oct 09 08:14:41 raspberrypi4 kernel: [    467]     0   467     3611       43    61440      165             0 systemd-logind
Oct 09 08:14:41 raspberrypi4 kernel: [    469] 65534   469     1370        8    40960       48             0 thd
Oct 09 08:14:41 raspberrypi4 kernel: [    478]     0   478     3391       15    53248      149             0 wpa_supplicant
Oct 09 08:14:41 raspberrypi4 kernel: [    487]   108   487     1722        7    40960       71             0 avahi-daemon
Oct 09 08:14:41 raspberrypi4 kernel: [    493]     0   493   211693       87   147456       71             0 nscd
Oct 09 08:14:41 raspberrypi4 kernel: [    520]     0   520      795       36    32768      125             0 dhcpcd
Oct 09 08:14:41 raspberrypi4 kernel: [    582]     0   582    23072       30    53248       10             0 rngd
Oct 09 08:14:41 raspberrypi4 kernel: [    629]   118   629    32975       59   102400      620             0 freshclam
Oct 09 08:14:41 raspberrypi4 kernel: [    633]   122   633     1504       15    40960       45             0 epmd
Oct 09 08:14:41 raspberrypi4 kernel: [    637]     0   637    79236      804   229376    14528             0 meyectl
Oct 09 08:14:41 raspberrypi4 kernel: [    638]     0   638    18394       78   126976      528             0 nmbd
Oct 09 08:14:41 raspberrypi4 kernel: [    641]     0   641     3510       25    53248      211             0 wpa_supplicant
Oct 09 08:14:41 raspberrypi4 kernel: [    647]  1001   647   312142        0   118784      827             0 syncthing
Oct 09 08:14:41 raspberrypi4 kernel: [    650]     0   650     1836        1    49152       60             0 vncserver-x11-s
Oct 09 08:14:41 raspberrypi4 kernel: [    652]     0   652   538921     2322   299008     1367          -999 containerd
Oct 09 08:14:41 raspberrypi4 kernel: [    658]   121   658     3789      170    57344      173             0 mosquitto
Oct 09 08:14:41 raspberrypi4 kernel: [    661]     0   661     1386        0    40960       27             0 agetty
Oct 09 08:14:41 raspberrypi4 kernel: [    665]     0   665    61072        0   106496      438             0 ModemManager
Oct 09 08:14:41 raspberrypi4 kernel: [    677]     0   677     7118      229    86016      367             0 vncserver-x11-c
Oct 09 08:14:41 raspberrypi4 kernel: [    683]     0   683     3428        0    61440      234         -1000 sshd
Oct 09 08:14:41 raspberrypi4 kernel: [    738]   115   738     2682       31    53248      136             0 chronyd
Oct 09 08:14:41 raspberrypi4 kernel: [    761]     0   761     2208        1    40960      160             0 vncserver
Oct 09 08:14:41 raspberrypi4 kernel: [    767]     0   767    27339      294   139264     2509             0 Xvnc-core
Oct 09 08:14:41 raspberrypi4 kernel: [    796]   115   796     2649        0    53248      138             0 chronyd
Oct 09 08:14:41 raspberrypi4 kernel: [   1210]   113  1210    60921        0   102400      948             0 colord
Oct 09 08:14:41 raspberrypi4 kernel: [   1267]     0  1267      530        0    40960       34             0 hciattach
Oct 09 08:14:41 raspberrypi4 kernel: [   1272]     0  1272     5977        0    73728      307             0 bluetoothd
Oct 09 08:14:41 raspberrypi4 kernel: [   1873]  1001  1873   329583     9415   278528      548             0 syncthing
Oct 09 08:14:41 raspberrypi4 kernel: [   1950]     0  1950     2026        1    49152      134             0 dbus-daemon
Oct 09 08:14:41 raspberrypi4 kernel: [   1953]     0  1953      515        0    32768       26             0 xstartup
Oct 09 08:14:41 raspberrypi4 kernel: [   2028]     0  2028    62663        1   110592      432             0 lxsession
Oct 09 08:14:41 raspberrypi4 kernel: [   2055]     0  2055   675423     4110   434176     2140          -500 dockerd
Oct 09 08:14:41 raspberrypi4 kernel: [   2058]     0  2058    22471       56   159744      703             0 smbd
Oct 09 08:14:41 raspberrypi4 kernel: [   2113]     0  2113     1361        9    36864      105             0 ssh-agent
Oct 09 08:14:41 raspberrypi4 kernel: [   2122]     0  2122    21887       23   151552      710             0 smbd-notifyd
Oct 09 08:14:41 raspberrypi4 kernel: [   2123]     0  2123    21885       25   143360      708             0 cleanupd
Oct 09 08:14:41 raspberrypi4 kernel: [   2150]     0  2150    22473      170   155648      612             0 lpqd
Oct 09 08:14:41 raspberrypi4 kernel: [   2212]     0  2212    10608      269   122880     6572             0 miniserv.pl
Oct 09 08:14:41 raspberrypi4 kernel: [   2279]     0  2279    59434        1    90112      241             0 gvfsd
Oct 09 08:14:41 raspberrypi4 kernel: [   2287]     0  2287    95143        0    90112      232             0 gvfsd-fuse
Oct 09 08:14:41 raspberrypi4 kernel: [   2308]     0  2308    18089        0   114688      838             0 openbox
Oct 09 08:14:41 raspberrypi4 kernel: [   2316]     0  2316    46815        0   118784     1109             0 lxpolkit
Oct 09 08:14:41 raspberrypi4 kernel: [   2330]     0  2330   395226        0   536576     6391             0 pcmanfm
Oct 09 08:14:41 raspberrypi4 kernel: [   2367]     0  2367     1361        0    40960      115             0 ssh-agent
Oct 09 08:14:41 raspberrypi4 kernel: [   2392]     0  2392    76965        0    94208      161             0 agent
Oct 09 08:14:41 raspberrypi4 kernel: [   2914]     0  2914   201089    21536   692224     3985             0 motion
Oct 09 08:14:41 raspberrypi4 kernel: [   3274]     0  3274    23899      120   204800    15080             0 meyectl
Oct 09 08:14:41 raspberrypi4 kernel: [   3651]     0  3651   175870       26   167936      655             0 gvfs-udisks2-vo
Oct 09 08:14:41 raspberrypi4 kernel: [   3656]     0  3656    98433      143   122880      588             0 udisksd
Oct 09 08:14:41 raspberrypi4 kernel: [   3699]     0  3699    39257        1    61440      180             0 menu-cached
Oct 09 08:14:41 raspberrypi4 kernel: [   3764]   110  3764    38383        6    53248       54             0 rtkit-daemon
Oct 09 08:14:41 raspberrypi4 kernel: [   3795]     0  3795    58404        1    77824      178             0 gvfs-mtp-volume
Oct 09 08:14:41 raspberrypi4 kernel: [   3803]     0  3803    58445        1    81920      176             0 gvfs-goa-volume
Oct 09 08:14:41 raspberrypi4 kernel: [   3814]     0  3814    58903        1    81920      222             0 gvfs-gphoto2-vo
Oct 09 08:14:41 raspberrypi4 kernel: [   3820]     0  3820    77716        0    94208      235             0 gvfs-afc-volume
Oct 09 08:14:41 raspberrypi4 kernel: [   3837]     0  3837    77973       20    94208      286             0 gvfsd-trash
Oct 09 08:14:41 raspberrypi4 kernel: [   3865]     0  3865    40040        0    73728      153             0 gvfsd-metadata
Oct 09 08:14:41 raspberrypi4 kernel: [   4005]     0  4005   175346        1   270336     2341             0 lxpanel
Oct 09 08:14:41 raspberrypi4 kernel: [   4291]     0  4291    73010       30   143360      648             0 packagekitd
Oct 09 08:14:41 raspberrypi4 kernel: [  26958]     0 26958   436162        0   135168      245          -500 docker-proxy
Oct 09 08:14:41 raspberrypi4 kernel: [  26992]     0 26992   309443      697    98304      231          -998 containerd-shim
Oct 09 08:14:41 raspberrypi4 kernel: [  26994]     0 26994   309443      748   102400      203          -998 containerd-shim
Oct 09 08:14:41 raspberrypi4 kernel: [  27011]     0 27011   309379      722    98304      216          -998 containerd-shim
Oct 09 08:14:41 raspberrypi4 kernel: [  27046]     0 27046   309443      777   102400      213          -998 containerd-shim
Oct 09 08:14:41 raspberrypi4 kernel: [  27069]     0 27069   309443      702    98304      221          -998 containerd-shim
Oct 09 08:14:41 raspberrypi4 kernel: [  27085]     0 27085      922        0    36864       64             0 bash
Oct 09 08:14:41 raspberrypi4 kernel: [  27106]     0 27106      947        1    32768       63             0 bash
Oct 09 08:14:41 raspberrypi4 kernel: [  27124]     0 27124      106        1    28672       11             0 s6-svscan
Oct 09 08:14:41 raspberrypi4 kernel: [  27132]     0 27132   319422     2630   204800      221             0 portainer
Oct 09 08:14:41 raspberrypi4 kernel: [  27142]     0 27142      922        0    36864       63             0 bash
Oct 09 08:14:41 raspberrypi4 kernel: [  27167]     0 27167   107010        0   212992     5373             0 python3
Oct 09 08:14:41 raspberrypi4 kernel: [  27170]     0 27170    25238        1    94208     3558             0 python3
Oct 09 08:14:41 raspberrypi4 kernel: [  27192]     0 27192   409708      198   528384    27200             0 python3
Oct 09 08:14:41 raspberrypi4 kernel: [  27202]     0 27202       52        1    28672        4             0 s6-supervise
Oct 09 08:14:41 raspberrypi4 kernel: [  27203]     0 27203       48        0    24576        3             0 s6-linux-init-s
Oct 09 08:14:41 raspberrypi4 kernel: [  27228]     0 27228       52        1    28672        4             0 s6-supervise
Oct 09 08:14:41 raspberrypi4 kernel: [  27232]     0 27232       52        1    28672        4             0 s6-supervise
Oct 09 08:14:41 raspberrypi4 kernel: [  27250]     0 27250       49        1    28672        5             0 s6-ipcserverd
Oct 09 08:14:41 raspberrypi4 kernel: [  27300]     0 27300       52        1    28672        4             0 s6-supervise
Oct 09 08:14:41 raspberrypi4 kernel: [  27302]     0 27302  2051855   797012 14110720   129652             0 python3
Oct 09 08:14:41 raspberrypi4 kernel: [  27347]     0 27347    80903        0   253952    19809             0 piper
Oct 09 08:14:41 raspberrypi4 kernel: [ 235804]     0 235804     7661      163    77824      448             0 cupsd
Oct 09 08:14:41 raspberrypi4 kernel: [ 235814]     0 235814    44382        1   110592     1136             0 cups-browsed
Oct 09 08:14:41 raspberrypi4 kernel: [ 235943]     7 235943     4182        0    61440      209             0 dbus
Oct 09 08:14:41 raspberrypi4 kernel: [ 311660]     0 311660     2775      181    49152        0             0 vncserverui
Oct 09 08:14:41 raspberrypi4 kernel: [ 311661]     0 311661    10905     2844   122880     4281             0 /usr/share/webm
Oct 09 08:14:41 raspberrypi4 kernel: [ 311688]     0 311688     2851      133    57344        8             0 cron
Oct 09 08:14:41 raspberrypi4 kernel: [ 311696]     0 311696     3495      129    53248        0          -250 systemd-journal
Oct 09 08:14:41 raspberrypi4 kernel: [ 311698]     0 311698     2851      133    57344        8             0 cron
Oct 09 08:14:41 raspberrypi4 kernel: [ 311727]     0 311727      515       23    36864        0             0 sh
Oct 09 08:14:41 raspberrypi4 kernel: [ 311728]     0 311728      515       23    32768        0             0 sh
Oct 09 08:14:41 raspberrypi4 kernel: [ 311729]     0 311729      486       25    28672        0             0 run-parts
Oct 09 08:14:41 raspberrypi4 kernel: [ 311730]     0 311730      486       25    36864        0             0 run-parts
Oct 09 08:14:41 raspberrypi4 kernel: [ 311734]     0 311734      515       22    32768        0             0 fake-hwclock
Oct 09 08:14:41 raspberrypi4 kernel: [ 311735]     0 311735    22473      181   147456      599             0 lpqd
Oct 09 08:14:41 raspberrypi4 kernel: [ 311737]     0 311737      515       23    32768        0             0 apt-show-versio
Oct 09 08:14:41 raspberrypi4 kernel: [ 311738]     0 311738      515       24    32768        0             0 fake-hwclock
Oct 09 08:14:41 raspberrypi4 kernel: [ 311740]     0 311740     1660       25    36864        0             0 apt-show-versio
Oct 09 08:14:41 raspberrypi4 kernel: [ 311742]     0 311742      500       16    32768        0             0 date
Oct 09 08:14:41 raspberrypi4 kernel: [ 311746]     0 311746    22471       78   135168      681             0 smbd
Oct 09 08:14:41 raspberrypi4 kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=init.scope,mems_
allowed=0,global_oom,task_memcg=/,task=python3,pid=27302,uid=0
Oct 09 08:14:41 raspberrypi4-camera kernel: Out of memory: Killed process 27302 (python3) total-vm:8207420kB, anon-rss:
3188048kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:13780kB oom_score_adj:0
Oct 09 08:14:41 raspberrypi4 systemd[1]: systemd-journald.service: Failed with result 'timeout'.
Oct 09 08:14:41 raspberrypi4 systemd[1]: Failed to start Journal Service.
Oct 09 08:14:41 raspberrypi4 systemd[1]: systemd-journald.service: Consumed 15.872s CPU time.
Oct 09 08:14:41 raspberrypi4 systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at
3.
Oct 09 08:14:41 raspberrypi4 systemd[1]: Starting Daily apt upgrade and clean activities...
Oct 09 08:14:41 raspberrypi4 systemd[1]: Stopped Journal Service.
Oct 09 08:14:41 raspberrypi4 systemd[1]: Starting Journal Service...
Oct 09 08:14:42 raspberrypi4 systemd[1]: Started Journal Service.
Oct 09 08:14:32 raspberrypi4 systemd-udevd[175]: Worker [311841] terminated by signal 9 (KILL)
Oct 09 08:14:32 raspberrypi4 systemd-udevd[175]: ttyACM0: Worker [311841] failed
Oct 09 08:01:48 raspberrypi4 rtkit-daemon[3764]: Demoting known real-time threads.
Oct 09 08:14:25 raspberrypi4 dhcpcd[520]: route socket overflowed - learning interface state
Oct 09 08:14:25 raspberrypi4 rtkit-daemon[3764]: Demoted 0 threads.
After the restart HA started normally, but memory usage in the HA python3 process is again creeping up gradually.
Does anyone have any suggestions? Many thanks
Thanks for a response Nick, not sure you read my post fully, but basically I was asking for help on how to recover.
That thread tells you the issue and the steps needed to recover.
Short version: disable AMP 4.13.3, restart HA, then either roll back to AMP 4.13.2 or update to the the latest version. 4.13.4 seems stable from what people are reporting in the thread.
I’m sticking on 4.13.2 for a while. I’ll see what happens.
Thanks Nick.
Hoping this is now resolved. I stopped HA, wiped all my files apart from the db and log, putting them somewhere else. Restored the backup from 24.09.01 and then overwrote the db and log from the safely stored files. Re started HA and upgraded AMP to 4.13.4.
Looks ok at the moment, but will see what happens overnight.
So HA didn’t crash and neither did the pi4 overnight. However I think memory utilization or the HA process is overly high in my opinion: -
# free --mega -h
               total        used        free      shared  buff/cache   available
Mem:            3.6G        3.2G         64M        0.0K        332M        322M
Swap:           1.0G        1.0G        3.0M
Selection_999(570)
Will see what happens today.
So even with AMP 4.14.4, memory utilization for me slowly creeps upwards and then crashes my rpi4. I’ve this morning had to reboot and now I have disabled AMP. Will keep it this way for now.
So even though AMP is disabled I’m still seeing a slow memory leak, my pi crashed again last night with HA memory utilisation up at around 3GB again. I’ve now resorted to a cronjob that restarts the HA container every 12hours. Not really ideal.
Does anyone have any ideas on how I can diagnose this?
Many thanks
