HA 502: Bad Gateway
I have Home Assistant 0.112.4, try to use “Home Panel”(installed in “Add-on store”) after installation I had started it and try to open, it’s gives me Error - “502: Bad Gateway”. I have tried to restart this addon several times, but it gives same error.
Can some body help me?
me too still trying to find a solution
Got mine to work.
Unticked the ssl Box, and set the port to 8234
also added the logfile: error in yaml
I also was 502 error in Terminal ssh and fixed that with a stronger password.
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
logfile: error
