HA access from local network
hello,
I have few HA servers running at home on multiple locations without public IP address or possibility to have port forwarding, I was wondering if possible to access them using revers proxy that I do have available on public IP address, I’m trying to avoid having any VPN client installed on devices and using Nabu Casa
cheers.
this still looks like the solution you refereed to needs vpn client, right?
There are many solutions recommended in that thread. Some need a client, some do not. Pick what works for you.
getting back here after a wile, thanks for hint, the closes thing what i was able to achieve from that thread is cloudflare tunnel that worked but only on primary domain, doesn’t work on subdomain, so this is the cheapest but not for free.
what I still would like to do is to create a reverse proxy server (ideally in docker pot) that I have on internet with public IP and connect several HA that are behind NAT without public IP
anyone could guide me ?
thanks
anyone willing to share his/her know-how ?
You can use the Sensmos node—it still connects to the network, but you have access to its code on GitHub and can see exactly what’s going on.
On top of that, you get end-to-end (E2E) encryption. You also get another advantage: even if the HA server goes down, you still know what’s happening in your local network because the node itself acts like a gateway…
