I am trying to move away from DuckDNS and Port Forwarding, and activate Cloudflare tunnel.
What I have done so fare is the following:
- removed port forwarding rules in router
- stopped DuckDNS add-on
- removed HTTP configuration in configuration.yaml file
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
- installed and configured Cloudflare add-on
As result now I have:
Cloudflare tunnel is up and running
Home Assistant is “reachable” from “outside”, but the the loading of the home page throw a 400: bad request error (see below how SSL certificate is OK
no error in Cloudflare log:
I suspect that DuckDNS and Cloudflare are making some confusion,… even by disabling the DuckDNS add-on it might have something shared/in common that break Cloudflare… any idea?
