Are there any existing communities or projects that are involved with fitness tracker integration into Home Assistant?
I’ve found a couple of threads on the board but I’m looking for something more done from the angle of people who are enthusiasts of the device and want to integrate it with Home Assistant, rather than people who are primarily involved with Home Assistant and want to integrate their fitness tracker with it.
Hello!
Depending on the tracker device, you might be able to find a community integration inside of HACS (the Home Assistant Community Store)
It is relatively simple to setup assuming you have terminal access to your home assistant interface. You can find the setup instructions here: Prerequisites | HACS
Keep in mind that HACS and its integrations are not officially supported by home assistant, and you should disable any custom integrations if you are having issues.
A great example of a fitness tracker integration available in HACS is:
Sorry, I probably could have worded that better, I was thinking more of a community group or forum, rather than a HACS add on.
I’m looking for somewhere that people are discussing the topic.
Oh… Sorry. I’m not sure then
No problem. There might not be one.
