HA and Google Assistant - the devices not sync
Hi
I have some problem with Google Assistant
When I used it somtimes to turn on/off some device
The action it’s happen. The problem is the device show in HA not on, but it’s on.
The next example I use the Google Assistant to turn kitchen light. It’s turn on. But HA show it’s not
How I fix it?
It’s really not clear what you think those screenshots are showing. One is showing a scene right? And the other is showing a light group in lovelace? Not sure what you are showing here as the lights are all on.
With Google Assistant you need to be wary of using a light with the same name as a room (eg kitchen room AND light.kitchen as that will definitely lead to some unpredictable results)
