HA and Hunter Hydrawise Integration
Hello
Does anyone have experience integrating HA with Hunter Hydrawise Integration and a Personal Weather Station? Here’s my issue. The Hydrawise system seems to poll its weather information from a sourcethat are vastly different from my local Enviroment Canada Weather station and my PSW. Please see the scenario below.
For this past Monday, my Hydrawise System shows an 81% chance of rain (bottom left corner of image).
I have my Hydrawise rainfall trigger set to 71% chance of rain. That is if there is a 71% or greater chance of rainfall then the sprinklers aren’t going to activate.
According to two local weather sources on the same Monday there was a 40% chance of rainfall.
Environment Canada
My PSW
The issue is with the “Hydrawise information” as it prevented my lawn from getting watered (83% chance of precipitation is higher than the 71% trigger value). If it were using “my information sources” the lawn would get watered (40% chance of rainfall is below the 71% trigger value).
Here are the sensors I have in Home Assistant:
Here are the triggers the Hydrawise system can work with:
Question: Is there a way to properly integrate real local data to control the Hydrawise system?
Thanking you in advance for any help that can be provided.
