Excuse me for being a noob. I just downloaded the software and successfully installed it onto my Pi. However I have a question. This Pi was usually dedicated to my Kodi setup. Now it appears as if I have to dedicate it to HA.
I know HA has a Kodi integration. However it appears as if it is only if Kodi is running on another system. Is this true or can the Pi run HA and Kodi on the same platform?
I have RetroPie installed and emulation station is what I boot into. I have Hass running and and I can choose to launch Kodi from emulation station. So yep I’m pretty sure there should be no issues.
You could follow this tutorial. Install Kodi. Then install home assistant using the AIO installer. Then just drop your config files in there and you should be good to go.
I know how to install Kodi on its own. What I dont know is how to get them both onto the same pi. When I initially made this thread I assumed you had to install HA and then Kodi later. However judging from your response it appears as if I can install Kodi first then HA.
Alright I can do that. I can install Kodi first. Then what?
Is there ANY docker container that runs Kodi? I’m guessing you don’t understand how difficult it is to run a CLIENT app with a GUI from Docker? It will basically change everything about what hassio is intended for.
If you really want Kodi on the pi alongside hassio, just run raspbian, and do the alternative install for hassio instead of running the hassio image that runs resinos.
just install dietpi on your pi and you can install all kinds of software from their integrated auto installer which also includes home assistant and many other apps including kodi
It is doable to have them both running on a Raspberry. You have to install the desktop version of Raspbian and manually install both Home Assistant and Kodi.
The problem with that solution is that you can’t have Hass.io addons. Is there any solution to have Home assistant with addons and Kodi running together?
Not true.
It is perfectly doable, and I found rather easy.
I had Kodi and HA running on the same Pi3 with zero problems, OS on the Pi was Raspbian Stretch Lite
Then installed Home Assistant into a python virtual environment, as detailed here
Also make sure to follow the help to have HA auto start as a service.
I had both running simultaneously side by side for some time and never had any issues. In fact I also had a Plex server running on the same Pi3!
Only issue I found was SD cards were becoming corrupted (happened 2 times), but I guess this was due to the constant writing for the HA log, which I think is now improved in the latest version…im sure ill be corrected by the team if I’m wrong.
Bit late to join in, but i have Pi3 running OSMC as OS (is based on kodi).
Then HA in virtual environment and it runs very well. (I run kodi on all machines in house but this pi is not the mysql server for the network, that could impact performance)
