I have hassos setup via virtualbox on a windows machine. I have added addon mosquitto broker with default settings.
i have another MQTT client which is sending messages to mosquitto broker via topic=homeassistant/sensor/voltronic_Battery_voltage
When i go to Developer Tools -> MQTT -> Listen to a topic and type the above topic and start listening i can see all the messages (as below)
Message 111 received on homeassistant/sensor/voltronic_Battery_voltage at 9:00 PM:
52.4
QoS: 0 - Retain: false
My problem is i am using this sensor in lovelace.yaml and it says on my Dashboard
Entity not available: sensor.voltronic_Battery_voltage
Maybe i am missing a step. It seems like HA is not listening to the Mosquitto broker. Also i have not received any notification of this new sensor. any help appreciated. my skills are novice.
no, i haven’t created a sensor, probably thats the step i was missing. how do i create one?
this is what i have in my lovelace yaml
type: glance
- entity: sensor.voltronic_Battery_voltage
name: Battery Voltage (V)
type: sensor
show_header_toggle: false
i am also passing topic = homeassistant/sensor/voltronic_Battery_voltage/config
which looks like
Message 113 received on homeassistant/sensor/voltronic_Battery_voltage/config at 6:32 AM:
I have also updated my lovelace.yaml to use sensor in lowercase i.e. sensor.voltronic_battery_voltage
Its still not doing anything, I am getting message “Entity not available: sensor.voltronic_battery_voltage” on my dashboard. I dont see any new entitiy / sensor created in HA.
I know Mosquitto broker is receiving my messages, i am not sure why HA is not listening to them. do i need to use a specific user/pass? currently i am using the same credential i use to login to HA. Or is there another configuration or step i need to do in HA to get it to listen to the MQTT?
