Its another rainy day here. So I thought of migrating my Home automation from FreeNAS over to Proxmox.
Would there be anyone that has done this? Any pros or cons? And what would be the best OS to use in the VM to host HA and Node Red?
Proxmox is just the host. Same as esxi or hyper-v. The fact it’s running on proxmox is irrelevant. Yes. Lots of people have done it.
You can run HassOS directly on a VM or you can run a VM of any distro. Personally I would use Ubuntu, others will say Debian. It doesn’t matter. Either way I’d run it in docker. Either hassio in docker or home assistant in docker alongside nodered in docker. It makes things easier later on.
