HA and Wyze API integration
Hello! My Wyze API integration no longer works on HA.
The issue began about a month ago, when HA was hosted on a MacMini VM. Now it’s on a HomeAssistant Green. When my backup was on HA Green, I had connection to my Wyze lights. At some point during my HA software updates, I lost access to Wyze again.
This is the error message I received:
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:151
First occurred: 3:54:33 PM (14 occurrences)
Last logged: 3:54:44 PM
Detected code that calls async_forward_entry_setup for integration, wyzeapi with title: and entry_id: b0f4e744b2c6f7eff372188a2285da88, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
Detected code that calls async_forward_entry_setup for integration wyzeapi with title: and entry_id: b0f4e744b2c6f7eff372188a2285da88, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
What I’ve tried:
  • disabling my VPN
  • refreshing the Wyze API key and using the new key ID and API key
  • creating a new Wyze account, creating a new API key, and using the new details on HA
  • fully rebooting HA and trying again
  • changing the IPV4 DNS server to 8.8.8.8 and leaving the gateway address on 192.168.0.1
Has anyone else experienced this problem before or something similar?
Resolved! HA’s network configuration was incorrect on the router.
