Core 2024.10.2
Supervisor 2024.10.2
Operating System 13.1
Frontend 20241002.3
on Raspberry Pi and it works OK.
Recently I bought a Samsung Galaxy Tab A9+ and installed & configured Home app from Google Play.
Problem is that when I launch Home app the overview looks strange (pls check attatchmen) but when I launch Chrome browser with URL ‘homeassistant.local:8123/lovelace-triglyfen/0’ it looks as it should. Unfortunatly it in swedish …
It looks like you got a different dashboard. Did you login as the same user, and did you see if you have the right dashboard selected? If you logged on as a differernt user, you may not have rights to see the right dashboard. Open the menu and check your profile / settings.
This looks like a totally different dashboard for a different user. There’s no raspberry pi entities on the app, nor are there any shortcuts to the other dashboards at the top
Yes … I used wrong Dashboard.
When choosing my customized Dashboard it works OK.
My mistake … for my present HA clients like Android mobile, computer browser and a different surfpad I had define my Dashboard as default but when I installed HA from scratch on a new surfpad I forgot to choose my customized Dashboard … know that for next time.
All in all … problem solved and thanks for support.
