HA Assist M5 Echo - LED on at all times?
Hey, i’ve just upgraded an M5 echo to the latest Assist - it’s all working but a purple LED is at full brightness the whole time and the LED control is showing as unavailable in my HA.
Flashed a new M5 echo and get the same behaviour - is this expected?
Can i disable this somehow - as it will light up a room at night at current brightness.
Appreciate any advice anyone can offer.
Flashed using the web-installer from the “$13 voice assistant” blog post.
Enabled the LED device in HA and can now turn the light off.
Still struggling with this actually.
Whenever the wake word detection is enabled, the LED is on full brightness.
If i turn off the LED, it turns back on after a few seconds, looking at the log it say it was caused by the light.turn_off service, which doesn’t make sense to me?
Log of me turning off both LEDs, and one immediately coming back on, but not the other.
I was able to change the LED brightness by changing some of the options within the config file.
Example file is here:
There are two main areas to adjust LED brightness:
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_wake_word
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                blue: 100%
                red: 100%
                green: 0%
                brightness: 100% # Edit standby brightness (Purple)
                effect: none
          else:
            - light.turn_off: led
voice_assistant:
  microphone: echo_microphone
  speaker: echo_speaker
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100% # Edit listening brightness (Blue pulse)
        effect: pulse
  on_tts_start:
    - light.turn_on:
        blue: 0%
        red: 0%
        green: 100%
        brightness: 100% # Edit voice response brightness (Green pulse)
        effect: pulse
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
    - script.execute: reset_led
  on_error:
    - light.turn_on:
        blue: 0%
        red: 100%
        green: 0%
        brightness: 100% # Edit error brightness (Red)
        effect: none
    - delay: 1s
    - script.wait: reset_led
    - lambda: |-
        if (code == "wake-provider-missing" || code == "wake-engine-missing") {
          id(use_wake_word).turn_off();
Hope that helps you out
Thanks, appreciate the prod in the right direction.
Cool! However, how do I do this. The default config for the Atom in ESPHome is very limited. Should I replace it with the full config you posted or can I just change the brightness options under substitions? If so, how, can you give an example? Thanks!
Use the full config.
Change this line:
I’ve set brightness to 0% when on standby.
Hope that helps.
Thanks, got it working!
For anyone else who wants easier instructions:
  1. Comment out these lines:
# packages:
#   m5stack.atom-echo-voice-assistant: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
# esphome:
#   name: ${name}
#   name_add_mac_suffix: false
#   friendly_name: ${friendly_name}
Note you should have something that looks like this at the end:
substitutions:
  friendly_name: [redacted]
# packages:
# esphome:
#   name: ${name}
api:
  encryption:
    key: [redacted]
  1. Then paste this in at the end of your file. I’ve already set and commented on brightness: 100% to brightness 0% under the script section:
esphome:
  project:
    version: "1.0"
  min_version: 2023.10.0
  on_boot:
    - priority: -100
      then:
        - wait_until: api.connected
        - delay: 1s
        - if:
            condition:
            then:
              - voice_assistant.start_continuous:
esp32:
  board: m5stack-atom
  framework:
    type: esp-idf
logger:
ota:
dashboard_import:
  package_import_url: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
improv_serial:
i2s_audio:
  i2s_lrclk_pin: GPIO33
  i2s_bclk_pin: GPIO19
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO23
    adc_type: external
    pdm: true
speaker:
    i2s_dout_pin: GPIO22
    dac_type: external
    mode: mono
voice_assistant:
  auto_gain: 31dBFS
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: pulse
  on_tts_start:
    - light.turn_on:
        blue: 0%
        red: 0%
        green: 100%
        brightness: 100%
        effect: pulse
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
  on_error:
    - light.turn_on:
        blue: 0%
        red: 100%
        green: 0%
        brightness: 100%
        effect: none
    - delay: 1s
    - lambda: |-
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_click:
      - if:
          condition:
            switch.is_off: use_wake_word
          then:
            - if:
                condition: voice_assistant.is_running
                then:
                  - voice_assistant.stop:
                else:
                  - voice_assistant.start:
          else:
            - delay: 1s
light:
  - platform: esp32_rmt_led_strip
    entity_category: config
    pin: GPIO27
    default_transition_length: 0s
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    rmt_channel: 0
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                blue: 100%
                red: 100%
                green: 0%
                brightness: 0% ## Made this 0% from 100% for standby
                effect: none
          else:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
    name: Use Listen Light
    optimistic: true
    on_turn_on:
    on_turn_off:
external_components:
  - source: github://pr#5230
    components:
      - esp_adf
    refresh: 0s
esp_adf:
Then install
