As per https://github.com/home-assistant/core/issues/24317, attempted to outline requirements for hass to support date ranges in the built-in automation.
As github issues are not for enhancements, moving here:
Component/platform:
Description of problem:
The conditions allow for sun level, time, etc; but no “date range”.
Use Case (0): Basic Date Ranges
, consider a permanently installed receptacle/switch where the user wants to activate it (ON/OFF) at specific time(s) in the day, but ONLY between certain date ranges in the year.
Use Case (1): Seasonal Re-purposing
, I have a seasonal outdoor switch on zwave; in the summer it shall control a water fountain, in the winter it shall control exterior Winter holiday season lights
(i’d like to be able to program HA once for the summer season ranges, and winter time; then if the switch exists, the automation for the appropriate action/times will apply)
Use Case (2): Electrical Utility peak/off-peak seasonal changes
, consider we wish to program certain devices OFF during peak-electrical times; this can be satisified by time conditions, EXCEPT if your utility changes peak times by season. Consider: https://www.wnhydro.com/en/your-home/time-of-use-rates.asp.
(in a perfect world utilities might expose APIs, which would render a separate enhancement to build a “electrical-time-of-use” component similar to https://www.home-assistant.io/components/workday/) - but in the absence of that, the user could program semi-annually their date ranges to match the time-of-use seasonal changes.
Use Case (3): Basic Date Listings and Patterns
, what if a user would like the “1st of every month” or “every other week” or etc?
(not currently in scope)
Problem-relevant configuration.yaml
entries and (fill out even if it seems unimportant):
- extend for date?
, of note, it already has a subsequentweekday
filter; so extension for date-range seems reasonable
Additional information:
Feature Suggestion / Idea
(open to implementing myself, would look for stakeholder agreement to the idea first)
Requirements
PROPOSED
- The
time
condition component MUST support an additional filter(s) to control date ranges - Date ranges MUST support the most common calendar used by most of the world (https://en.wikipedia.org/wiki/Gregorian_calendar)
- This date-range MUST be an OPTIONAL filter (if unspecified, MUST NOT impact any of the existing
time
orweekday
functionality) - Optional filters to time (
weekday
,date_...
) MUST be COMBINATION_AND logic (not OR) - The configurations for date ranges MUST be two separate configuration entities (i.e.
date_start
anddate_end
) - Date ranges MUST be inclusive to the dates specified
- SHALL support standard ISO formatting
YYYY-MM-DD
- MUST support ranges across months and year boundaries
- MUST handle leap days/years (and any typical scenarios where dates can come and go)
- MUST support via
configuration.yml
as well as GUI automation builder (NOTE:weekday
is not currently in the UI)
References
As workarounds, I found:
- template automations that enable/disable automations using
value_template
as per Automation During Date Range - maybe the
schedy
hass-app helps? https://hass-apps.readthedocs.io/en/stable/apps/schedy/configuration.html
