Backup failed because NAS did not respond soon enough, it auto wakes but needs time. HA backup needs an option for delay also WOL would be nice, if device can’t wake itself.
Wake on LAN.
nickrout
(Nick Rout)
January 12, 2025, 7:07pm
2
Ha has wol support. Start the nas enough time before the 4.45 am start.
Disable auto backup and create your own automation that does exactly what you describe
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
January 15, 2025, 3:45am
4
Hi Firefly ,
As rrooggiieerr said, do it like you did before…
There have been a lot of questions on how to do a backup if you want to run it manually, not using the awesome automatic tools.
This is a bunch of ways to back-up your system and not use the new 2025.1 introduced automatic stuff.
Choices are good to have. Make sure you are making the right choice.
Now while I do like the new method and do suggest using encryption, the options are still available to not use encryption and to use a different method.
Here are some options. Some were in the HA D…
