I have some issues with my HA environment together with the App and position tracking.
Current Setup:
- HA is installed on dedicated x86 baremetal device with HAOS
- SSL let’s encrypt certs installed on HA
- nginx reverse proxy is running on OpenWRT Router, also installed with let’s encrypt certs, all collected in DNS mode (route53)
- All connections to HA going through reverse proxy, also connections coming from LAN.
- Direct access to %HAIP%:8123 is also possible (from LAN)
- HA WebGUI and App is working fine from inside and outside my local network.
- I have the HA app installed on different devices (Xiaomi Mi9, Samsung and ipad) and the behavior described below is the same on all devices. All energy optimizations are disabled.
- On the ipad app I can see that connection and websocket connection is fine.
- I do not use an internal URL configuration for the app
Problem description
- After a few hours I do not get any update from the app devices like geo location or battery level anymore. If I open the app it will connect immediately and all is working, also the app sensor data is updated.
- If I am using the internal HA IP and Port and an established VPN Connection the app connection looks better because I got the sensor data for more than 24h hours.
nginx.conf config
worker_processes auto;
user root;
include module.d/*.module;
events {}
http {
access_log off;
log_format openwrt
'$request_method $scheme://$host$request_uri => $status'
' (${body_bytes_sent}B in ${request_time}s) <- $http_referer';
# Connection header for WebSocket reverse proxy
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
include mime.types;
default_type application/octet-stream;
sendfile on;
client_max_body_size 128M;
large_client_header_buffers 2 1k;
server_names_hash_bucket_size 64;
proxy_request_buffering off;
proxy_buffering off;
gzip on;
gzip_vary on;
gzip_proxied any;
root /www;
include conf.d/*.conf;
nginx server config
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name ***;
ssl_certificate ***;
ssl_certificate_key ***;
ssl_session_cache shared:SSL:32k;
ssl_session_timeout 64m;
ssl_protocols TLSv1.2;
access_log off; # logd openwrt;
location / {
proxy_pass https://192.168.1.1:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
If I check the location tracking log in the android app, I just see “send failed” during the time where I do not get sensor data from the app. That means that the App itself will not be closed and is still running.
Any idea what I did wrong? Have anybody experience with the OpenWRT own nginx version? I’m slowly running out of ideas on how I can narrow down the error even further.
