HA behindy nginx reverse proxy
Hi Community!
I’m using an Nginx server as unique entry to various “objects” in my internal lan (i.e
https:\my-ddns-domain\my-ipcam-garage, https:\my-ddns-domain\my-nextcloud, etc…).
I wish to add a new entry like https:\my-ddns-domain\ha.
Using simply:
location /ha {
    proxy_pass http://internal-ip-addr:8123;
    proxy_set_header Host $host;
    proxy_http_version 1.1;
    proxy_set_header X-Real-IP         $remote_addr;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection $connection_upgrade;
returns a blank page with 404 not found.
If I add a rewrite statement, then I receive only a blank page with the Banner: it seems that all subsequent requests forget the “/ha”.
Any suggestion(s)? Any man-page to read?
Thanks in advance,
m
This is my ha.subdomain.conf
# make sure that your dns has a cname set for homeassistant and that your homeassistant container is not using a base url
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name ha.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    # enable for ldap auth, fill in ldap details in ldap.conf
    #include /config/nginx/ldap.conf;
    location / {
        # enable the next two lines for http auth
        #auth_basic "Restricted";
        #auth_basic_user_file /config/nginx/.htpasswd;
        # enable the next two lines for ldap auth
        #auth_request /auth;
        #error_page 401 =200 /login;
        include /config/nginx/proxy.conf;
        resolver 127.0.0.11 valid=30s;
        set $upstream_app homeassistant;
        set $upstream_port 8123;
        set $upstream_proto http;
        proxy_pass http://10.0.0.67:8123;
    location /api/websocket {
        proxy_set_header Connection "upgrade";
You cannot access HA through a subdirectory.
It must be a subdomain.
@francisp, @AaronCake: thanks to both!!!
Double thanks to @francisp: your config works perfectly (with some corrections for my lan…)
m
