HA Bridge stopped working (?)
I had HA bridge working quite nicely for two weeks. However now down for two days and starting the service (sudo systemctl start habridge) does not help.
Now looking at the HA bridge on githib (GitHub - bwssytems/ha-bridge: Home automation bridge that emulates a Philips Hue light system and can control other systems such as a Vera, Harmony Hub, Nest, MiLight bulbs or any other system that has an http/https/tcp/udp interface. This is a compact impl to run on small format computers. This is impl started from this project https://github.com/armzilla/amazon-echo-ha-bridge.) there seems to be a new version (3.2.0) which was launched also two days ago. So I’m thinking it’s related to this (?)
I used below to get HA Bridge up and running. Any tips on how to get HA bridge back?
Below the result of systemctl status habridge.service
See if any of the info in this post helps out:
Indeed . This solved it!
