Dear Community,
I seem to have a rather wheired issue with homeassistant, and it’s installation.
For context:
I am using a Raspberry Pi 3B
I have installed raspbian desktop without recommendet Software on my pi a couple of days ago, because I need a UI in order to launch several applications at the same thime and look at their windows.
I have the Mosquitto MQTT server installed already,
and zigbee2mqtt is running with a cc2531 zigbee adapter.
To get Python 3.8 running on the Pi, i compiled it myself with the following instructions:
https://raspberrypi.stackexchange.com/questions/116118/updating-python-3-7-to-3-8
I don’t know if that matters but i compiled Python on all 4 cores (as stated in the instructions) and the pi got to over 82°C before I realizid it was getting hot, then i used a fan to cool it down to around 40°C (I do have a heatsink on my Pi). Then i went to install HA Core with the instructions on the HA website:
https://www.home-assistant.io/docs/installation/raspberry-pi/
When i was as far as installing HA using pip, it already took painfully long, and it is definitely not my Internet connection that is causing troubel here. Anyway, once it finally finished and I started it using the hass command, it really went of. Now not really much was happening anymore. The Pi became really inresponsive, it did react to some things, but the kernel was almost frozen, the desktop didn’t really do anything, and the charts in the top right hand corner of the pi showing temerature and CPU load where frozen at some point. After some time Home Assistant did give the following Error messages (I only have a foto of the screen, because i couldn’t copy the text anymore as it was frozen):
(In the image you can see i am not using the newest version of pip, because even if I install it using the provided command, it still doesn’t use the newest version)
At that point I restarted the Pi using the reset jumper. I rebooted it a few times properly afterwards and tried again, only to see that HA was doing even less than before. It eighter put out nothing on the command prompt, or warned about an unfinished session but no more.
I may note that i have also tried installing using venv before with the same result and the same slow installation.
Thats where I am now. I don’t know what i did wrong, I even thought about a CPU Core beeing damaged by overheating, though that seems quit unrealistic.
I hope someone can help me
MrElektron
