dear, hi!
I got my installation broken (5-years lifespan) after attempting to update to 2025.3.1.
not better specified unknown error, tried to restore the latest full backup via CLI, unsuccessful…it stops with not better specified unknown error.
now:
How can I better follow up better on logs via CLI? it shoots all the lines without allowing me to read the backward ones…this will allow me to post the log and make better troubleshooting
Any hint to tell me on how to lose 5 years of projects and improvemenets even if I have a full backup to start with?
please help me, for me and my family is painful without HA.
Start by explaining what’s wrong, “broken” is not saying much. Does it start up and then crash? Does it not boot? Have you tried booting in safe mode? How are you running HA?
Hi there.
Broken means that even if from the CLI all is set and right, I could not access it anymore neither from LAN or NABU or DuckDNS.
tried to boot in safe mode, without success. there is something gone in core but I could not figure it out.
HA is running in a VMware ESXi VM.
I can also for the future recommend running snapshot based backups if you are running esxi, makes restores a lot easier. Veeam has a free community edition.
I’m trying now the fix.
If I will not come out of this s*it I would move to a proxmox on NUC installation.
the things stopping me are the devices management, how to pass a port to a proxmox VM, how to manage the space of proxmox VM, because I’m not that knowledgeable on linux management.
if you have something to advice a bit more “UI” instead than “CLI” it’s really appreciated.
in the meantime, supervisor repaired as per response from CLI
core in progress.
you’re definitely right.
the backup is valid only if you test it.
I tried to restore it into another freshly created VM but without success. as I wrote, I san not knowledgeable enought to retrieve all the logs from CLI, so I cannot point what went wrong.
I tried to update to 2025.3.1 when all this happened, yes.
you didn’t get me.
I’m assuming to make everything from scratch an try to take out something in yaml from the backup of the old one…any hint on the rebuild?
no no don’t get me wrong…
my whole experience with HA is 5 years old!
of course I always updated everything everytime!
and @dzmiller why should I discard the possibility of new learnings? think I could learn new skills also in VM management in proxmox, since in ESXi I think I know enough to manage a VM.
