HA cannot be started in debug mode in pycharm
I updated the latest code of the dev branch, and it cannot be started in debug mode, but it can be started in non-debug mode. The commands displayed in the pycharm console are:
debug mode command: /Users/xxx/workspace/ha/core/venv/bin/python -X pycache_prefix=/Users/xxx/Library/Caches/JetBrains/PyCharm2024.1/cpython-cache /Applications/PyCharm.app/Contents/plugins/python/helpers/pydev/pydevd.py --module --multiprocess --qt-support=auto --client 127.0.0.1 --port 60907 --file homeassistant.main
non-debug mode command: /Users/xxx/workspace/ha/core/venv/bin/python -m homeassistant.main
the error message is :
/Users/xxx/workspace/ha/core/venv/bin/python -X pycache_prefix=/Users/xxx/Library/Caches/JetBrains/PyCharm2024.1/cpython-cache /Applications/PyCharm.app/Contents/plugins/python/helpers/pydev/pydevd.py --module --multiprocess --qt-support=auto --client 127.0.0.1 --port 60907 --file homeassistant.__main__
Connected to pydev debugger (build 241.17890.14)
Exception ignored in: <function Task.__del__ at 0x102d53f60>
  File "/opt/homebrew/Cellar/[email protected]/3.12.4/Frameworks/Python.framework/Versions/3.12/lib/python3.12/asyncio/tasks.py", line 150, in __del__
    self._loop.call_exception_handler(context)
AttributeError: 'NoneType' object has no attribute 'call_exception_handler'
  File "/Applications/PyCharm.app/Contents/plugins/python/helpers/pydev/pydevd.py", line 1563, in _exec
    runpy._run_module_as_main(module_name, alter_argv=False)
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/Users/xxx/workspace/ha/core/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/Users/xxx/workspace/ha/core/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/Users/xxx/workspace/ha/core/homeassistant/runner.py", line 190, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/Applications/PyCharm.app/Contents/plugins/python/helpers-pro/pydevd_asyncio/pydevd_nest_asyncio.py", line 243, in run_until_complete
    return f.result()
  File "/opt/homebrew/Cellar/[email protected]/3.12.4/Frameworks/Python.framework/Versions/3.12/lib/python3.12/asyncio/futures.py", line 203, in result
    raise self._exception.with_traceback(self._exception_tb)
  File "/opt/homebrew/Cellar/[email protected]/3.12.4/Frameworks/Python.framework/Versions/3.12/lib/python3.12/asyncio/tasks.py", line 314, in __step_run_and_handle_result
    result = coro.send(None)
  File "/Users/xxx/workspace/ha/core/homeassistant/runner.py", line 158, in setup_and_run_hass
    hass = await bootstrap.async_setup_hass(runtime_config)
  File "/Users/xxx/workspace/ha/core/homeassistant/bootstrap.py", line 307, in async_setup_hass
    await async_from_config_dict(config_dict, hass) is not None
  File "/Users/xxx/workspace/ha/core/homeassistant/bootstrap.py", line 434, in async_from_config_dict
    await async_load_base_functionality(hass)
  File "/Users/xxx/workspace/ha/core/homeassistant/bootstrap.py", line 404, in async_load_base_functionality
    create_eager_task(get_internal_store_manager(hass).async_initialize()),
  File "/Users/xxx/workspace/ha/core/homeassistant/util/async_.py", line 37, in create_eager_task
    return Task(coro, loop=loop, name=name, eager_start=True)
TypeError: _patch_task.<locals>.task_new_init() got an unexpected keyword argument 'eager_start'
sys:1: RuntimeWarning: coroutine '_StoreManager.async_initialize' was never awaited
Process finished with exit code 1
There is another question. I step into the code and found that the code here called the del method. Why not the init method?
Please help me, thanks!
Why are you running the development branch?
For assistance with that try the Home Assistant Discord server development channels.
Just for learning.
I debugged the development branch like this a few months ago and it can be started , but now it doesn’t work.
thanks!
