I have installed Rasbian and ran the AIO installer.
I was able to get access to my Aeon Z-wave stick using open zwave control panel.
Using a RPi3.
I have added the following to my configuration.yaml file:
zwave:
usb_path: /dev/ttyAMA0
config_path: /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/libopenzwave-0.3.2-py3.4-linux-armv71.egg/config/
The error in the dev-info says:
17-02-27 22:21:46 WARNING (Dummy-15) [openzwave] Z-Wave Notification DriverFailed : {'nodeId': 255, 'notificationType': 'DriverFailed', 'homeId': 0}
I made sure that user homeassistant has permissions to the configuration.yaml file.
For some reason I cannot get zwave item to show up in the HA front end.
dramamoose
(David Morris-Stump)
February 28, 2017, 6:33am
2
Your USB path is configured wrong, I thin. You’ve got /dev/ttyAMA0, but it (likely) is /dev/ttyACM0
You can test this by using ls /dev/ttyACM* on the pi’s command line.
dramamoose:
Facepalm… You may be right I will double check it when I get home.I might have manual changed it since I was trying to figure out the preformatted text thing.
Thank you, I should have seen that. I spent a bunch of time making sure the config path was right. Not sure how I ham fisted the wrong USB port in there.
RicardoNL
(Ricardo de Vries)
January 12, 2018, 7:56am
5
Hey Thank you guys! i had the same problem and it is fixed thanks to this post!
