I have recently updated HS core and operating system and since then I no longer can communicate with Nabu Cassa (Cloud). below is the log info:
* Setup failed for cloud: Unable to import component: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.10 from "/usr/local/bin/python3" * The NumPy version is: "1.23.2" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: Error loading shared library _LR: No such file or directory (needed by /usr/local/lib/python3.10/site-packages/numpy/core/../../numpy.libs/libopenblas_armv8p-r0-8b2c479e.3.20.so)
Have already checked the link in the log but could not figure out a solution.
Appreciate any comment to assist me resolving the issue
