I have installed HA Companion on my ipad which has IOS 12.x.x and the latest (today’s) icloud3 version on HA. Using that ipad on an outside network, I can connect to: myname.duckdns.com:8123 through safari and chrome (my router doesn’t allow loopback so I can’t test on my local network). If I try to connect HA companion using http://myname.duckdns.com:8123 I get an error that talks about shared token manager.token error error 1.
I have tried with and without lets_encrypt. With lets_encrypt, I can connect with chrome, but not safari (that’s a separate issue, likely with self signed certificates)…but I get the same error trying to connect HAC using https://myname.duckdns.com:8123
Note: self signed certificates are a real problem with a router that doesn’t support loopback…I haven’t figured that out yet so I’m going to run without SSL for a short time so my inhouse ipads can run HA.
Is there a work around.
