I´m a beginner and just installed Home Assistant on a Rasp4. I can get access to HA on the Pi with my laptop by browser through a firefox tab with [http://homeassistant.local:8123/lovelace/0]
Additionally I downloaded the Home Assistant Companion App via Playstore.
After opening the APP it searches for an instance but doesn´t find one. There is a button to type in the connection adress manually, but neither of the following works:
http://
- IP-AdressofthePI (Found the adress in the Fritzbox dialog under Network)
- homeassistant.local
- homeassistant.local:8123
Pi is connected by LAN to my Fritzbox 7590, Laptop connected to my LAN by LANCable, Smartphone by Wifi to my Fritzbox.
What is the problem?
Do I have to set up something on the PI/Home Assistant before to get access from mobile phone?
Thanks for help
