HA Companion App - include the GPS fix time as a device_tracker attribute
As per the title, many uses of GPS data need to know the time of the GPS fix/data. For some reason this is not included in the integration - on the iOS app for sure.
I don’t know why this is and it would be so good if it could be added as an attribute to the device_tracker entity.
Thank you!
Every entity has a timestamp for when it was updated. If you want that information, just create a template sensor that extracts it.
template:
- sensor:
  - name: Last GPS
    unique_id: a2439dfe8a98e
    state: "{{ states.sensor.gps.last_updated }}"
    device_class: timestamp
You can see this when you click on an entity without needing to create a template sensor.
