Hello all,
I am trying to use the minimal version to connect to my HA locally. There is no https configured (I am just using internally) and after a long search in the forum, I am not able to find the right way to set up. From the Chrome app, I am able to connect to HA with no problems.
When I open the app, I can add the address for the server, even log in (I checked that is correctly because if I add an incorrect user/pass it tells me). Just right after the log in, it tells me that there is a problem connecting with HA.
Adding also the log, in case anyone can help me!
(I can’t attach the full log because of body character limitation, hope this is useful)
Thanks!
--------- beginning of main
01-26 11:36:08.074 1631 1631 D WM-WrkMgrInitializer: Initializing WorkManager with default configuration.
01-26 11:36:09.072 1631 1636 I zygote64: Do partial code cache collection, code=15KB, data=28KB
01-26 11:36:09.072 1631 1636 I zygote64: After code cache collection, code=15KB, data=28KB
01-26 11:36:09.072 1631 1636 I zygote64: Increasing code cache capacity to 128KB
01-26 11:36:09.352 1631 1636 I zygote64: Compiler allocated 4MB to compile void kotlin.reflect.jvm.internal.impl.metadata.ProtoBuf$Class.<init>(kotlin.reflect.jvm.internal.impl.protobuf.CodedInputStream, kotlin.reflect.jvm.internal.impl.protobuf.ExtensionRegistryLite)
01-26 11:36:09.443 1631 1636 I zygote64: Do partial code cache collection, code=60KB, data=57KB
01-26 11:36:09.444 1631 1636 I zygote64: After code cache collection, code=60KB, data=57KB
01-26 11:36:09.444 1631 1636 I zygote64: Increasing code cache capacity to 256KB
01-26 11:36:09.937 1631 1636 I zygote64: Do full code cache collection, code=125KB, data=93KB
01-26 11:36:09.938 1631 1636 I zygote64: After code cache collection, code=120KB, data=64KB
01-26 11:36:09.956 1631 1636 I zygote64: Do partial code cache collection, code=120KB, data=67KB
01-26 11:36:09.957 1631 1636 I zygote64: After code cache collection, code=120KB, data=67KB
01-26 11:36:09.957 1631 1636 I zygote64: Increasing code cache capacity to 512KB
01-26 11:36:09.967 1631 1631 I zygote64: Deoptimizing java.lang.Appendable kotlin.collections.CollectionsKt___CollectionsKt.joinTo(java.lang.Iterable, java.lang.Appendable, java.lang.CharSequence, java.lang.CharSequence, java.lang.CharSequence, int, java.lang.CharSequence, kotlin.jvm.functions.Function1) due to JIT inline cache
01-26 11:36:10.040 1631 1631 I WebViewFactory: Loading com.android.webview version 61.0.3163.98 (code 316409850)
01-26 11:36:10.124 1631 1631 I cr_LibraryLoader: Time to load native libraries: 5 ms (timestamps 6359-6364)
01-26 11:36:10.169 1631 1631 I chromium: [INFO:library_loader_hooks.cc(136)] Chromium logging enabled: level = 0, default verbosity = 0
01-26 11:36:10.169 1631 1631 I cr_LibraryLoader: Expected native library version number "61.0.3163.98", actual native library version number "61.0.3163.98"
01-26 11:36:10.171 1631 1631 D NetworkSecurityConfig: Using Network Security Config from resource network_security_config debugBuild: false
01-26 11:36:10.297 1631 1662 D OpenGLRenderer: HWUI GL Pipeline
01-26 11:36:10.305 1631 1631 I Choreographer: Skipped 134 frames! The application may be doing too much work on its main thread.
01-26 11:36:10.720 1631 1662 I mali_so : [File] : hardware/rockchip/mali_so_src_of_midgard/driver/product/base/src/mali_base_kbase.c; [Line] : 1095; [Func] : base_context_deal_with_version_affairs_rk_ext;
01-26 11:36:10.720 1631 1662 I mali_so : arm_release_ver of this mali_so is 'r12p0-01rel0', rk_so_ver is '[email protected] '.
01-26 11:36:10.720 1631 1662 I mali_so : [File] : hardware/rockchip/mali_so_src_of_midgard/driver/product/base/src/mali_base_kbase.c; [Line] : 1111; [Func] : base_context_deal_with_version_affairs_rk_ext;
01-26 11:36:10.720 1631 1662 I mali_so : arm_release_vers are match. to set the full mali_ver '[email protected]' as value of 'sys.gmali.version'.
01-26 11:36:10.720 1631 1631 I RenderThread: type=1400 audit(0.0:1482): avc: denied { write } for name="property_service" dev="tmpfs" ino=8370 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=1
01-26 11:36:10.720 1631 1631 I RenderThread: type=1400 audit(0.0:1483): avc: denied { connectto } for path="/dev/socket/property_service" scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
01-26 11:36:10.728 1631 1662 I mali_so : [File] : hardware/rockchip/mali_so_src_of_midgard/driver/product/cmem/src/mali_cmem_hoard.c; [Line] : 559; [Func] : should_current_process_not_to_use_hoard;
01-26 11:36:10.728 1631 1662 I mali_so : WOULD use hoard.
01-26 11:36:10.740 1631 1662 I io.homeassistant.companion.android.minimal: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
01-26 11:36:10.740 1631 1662 I OpenGLRenderer: Initialized EGL, version 1.4
01-26 11:36:10.741 1631 1662 D OpenGLRenderer: Swap behavior 2
01-26 11:36:10.765 1631 1662 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
01-26 11:36:10.768 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:10.836 1631 1631 D SensorReceiver: Received intent: android.net.wifi.STATE_CHANGE
01-26 11:36:10.840 1631 1631 D SensorReceiver: Received intent: android.net.wifi.WIFI_STATE_CHANGED
01-26 11:36:10.842 1631 1650 W SensorReceiver: Device not registered, skipping sensor update/registration
01-26 11:36:10.842 1631 1631 D SensorReceiver: Sensor wifi_state corresponding to received event android.net.wifi.WIFI_STATE_CHANGED is disabled, skipping sensors update
01-26 11:36:10.842 1631 1631 D SensorReceiver: Received intent: android.media.RINGER_MODE_CHANGED
01-26 11:36:10.844 1631 1631 D SensorReceiver: Sensor audio_sensor corresponding to received event android.media.RINGER_MODE_CHANGED is disabled, skipping sensors update
01-26 11:36:10.884 1631 1631 I Choreographer: Skipped 33 frames! The application may be doing too much work on its main thread.
01-26 11:36:10.947 1631 1662 I [Gralloc]: Got handle 1 for fd 73
01-26 11:36:10.947 1631 1662 I [Gralloc]: leave, w : 1024, h : 600, format : 0x1,internal_format : 0x1, usage : 0xb00. size=2457600,pixel_stride=1024,byte_stride=4096
01-26 11:36:10.947 1631 1662 I [Gralloc]: leave: prime_fd=73,share_attr_fd=74
01-26 11:36:11.194 1631 1662 I [Gralloc]: Got handle 2 for fd 78
01-26 11:36:11.194 1631 1662 I [Gralloc]: leave, w : 1024, h : 600, format : 0x1,internal_format : 0x1, usage : 0xb00. size=2457600,pixel_stride=1024,byte_stride=4096
01-26 11:36:11.194 1631 1662 I [Gralloc]: leave: prime_fd=78,share_attr_fd=79
01-26 11:36:11.510 1631 1631 W zygote64: Class androidx.compose.runtime.snapshots.SnapshotStateList failed lock verification and will run slower.
01-26 11:36:11.510 1631 1631 W zygote64: Common causes for lock verification issues are non-optimized dex code
01-26 11:36:11.510 1631 1631 W zygote64: and incorrect proguard optimizations.
01-26 11:36:11.948 1631 1642 I zygote64: Background concurrent copying GC freed 29873(2MB) AllocSpace objects, 3(124KB) LOS objects, 50% free, 4MB/9MB, paused 252us total 109.074ms
01-26 11:36:12.063 1631 1631 I zygote64: Deoptimizing void androidx.compose.runtime.snapshots.StateRecord.<init>() due to JIT same target
01-26 11:36:12.173 1631 1662 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
01-26 11:36:12.230 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:12.241 1631 1662 W libEGL : EGLNativeWindowType 0x74d9d4b010 disconnect failed
01-26 11:36:12.276 1631 1648 D UrlRepository: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
01-26 11:36:12.296 1631 1631 I Choreographer: Skipped 45 frames! The application may be doing too much work on its main thread.
01-26 11:36:12.336 1631 1673 I WM-Processor: Moving WorkSpec (fec4a107-95f4-41a2-85e5-1f045f554581) to the foreground
01-26 11:36:12.354 1631 1648 D WebSockManager: Starting to listen to Websocket
01-26 11:36:12.370 1631 1650 D UrlRepository: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
01-26 11:36:12.371 1631 1650 D UrlRepository: Using external URL
01-26 11:36:12.371 1631 1650 W WebSocketRepository: No url to connect websocket too.
01-26 11:36:12.375 1631 1650 E WebSocketRepository: Unable to send message WebSocketRequest(message={type=mobile_app/push_notification_channel, webhook_id=null, support_confirm=true}, timeout=30000, [email protected], eventTimeout=0, [email protected]{EmptyQueue}(buffer:capacity=64,size=0), onResponse=null)
01-26 11:36:12.376 1631 1650 E WebSocketRepository: Unable to subscribe to mobile_app/push_notification_channel with data {webhook_id=null, support_confirm=true}
01-26 11:36:12.434 1631 1662 I [Gralloc]: Got handle 1 for fd 78
01-26 11:36:12.434 1631 1662 I [Gralloc]: leave, w : 1024, h : 600, format : 0x1,internal_format : 0x1, usage : 0xb00. size=2457600,pixel_stride=1024,byte_stride=4096
01-26 11:36:12.434 1631 1662 I [Gralloc]: leave: prime_fd=78,share_attr_fd=79
01-26 11:36:12.716 1631 1636 I zygote64: Do full code cache collection, code=252KB, data=160KB
01-26 11:36:12.718 1631 1636 I zygote64: After code cache collection, code=209KB, data=115KB
01-26 11:36:12.722 1631 1662 I [Gralloc]: Got handle 2 for fd 81
01-26 11:36:12.722 1631 1662 I [Gralloc]: leave, w : 1024, h : 600, format : 0x1,internal_format : 0x1, usage : 0xb00. size=2457600,pixel_stride=1024,byte_stride=4096
01-26 11:36:12.722 1631 1662 I [Gralloc]: leave: prime_fd=81,share_attr_fd=82
01-26 11:36:12.738 1631 1631 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
01-26 11:36:14.481 1631 1662 I [Gralloc]: Got handle 3 for fd 84
01-26 11:36:14.481 1631 1662 I [Gralloc]: leave, w : 1024, h : 600, format : 0x1,internal_format : 0x1, usage : 0xb00. size=2457600,pixel_stride=1024,byte_stride=4096
01-26 11:36:14.481 1631 1662 I [Gralloc]: leave: prime_fd=84,share_attr_fd=85
01-26 11:36:14.636 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.StateRecord androidx.compose.runtime.snapshots.SnapshotKt.readable(androidx.compose.runtime.snapshots.StateRecord, androidx.compose.runtime.snapshots.StateObject) due to JIT inline cache
01-26 11:36:14.762 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:14.763 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:14.764 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:14.764 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:14.765 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:14.766 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:14.768 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:14.837 1631 1681 D HomeAssistantSearcher: Service discovery started
01-26 11:36:14.933 1631 1636 I zygote64: Do partial code cache collection, code=248KB, data=169KB
01-26 11:36:14.933 1631 1636 I zygote64: After code cache collection, code=244KB, data=167KB
01-26 11:36:14.934 1631 1636 I zygote64: Increasing code cache capacity to 1024KB
01-26 11:36:15.015 1631 1681 I HomeAssistantSearcher: Service discovery found HA: name: Home, type: _home-assistant._tcp., host: null, port: 0, txtRecord:
01-26 11:36:15.034 1631 1662 I [Gralloc]: Got handle 4 for fd 87
01-26 11:36:15.034 1631 1662 I [Gralloc]: leave, w : 1024, h : 600, format : 0x1,internal_format : 0x1, usage : 0xb00. size=2457600,pixel_stride=1024,byte_stride=4096
01-26 11:36:15.034 1631 1662 I [Gralloc]: leave: prime_fd=87,share_attr_fd=88
01-26 11:36:15.049 1631 1681 I HomeAssistantSearcher: Service resolved: name: Home, type: ._home-assistant._tcp, host: /192.168.0.30, port: 8123, txtRecord: location_name=Home!base_url=http://192.168.1.26:8123
external_url=%internal_url=http://192.168.1.26:8123%uuid=bbe41baa40d447539b286d43e46fab5eversion=2023.1.7requires_api_password=True
01-26 11:36:15.052 1631 1681 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.Snapshot androidx.compose.runtime.snapshots.Snapshot$Companion.getCurrent() due to JIT inline cache
01-26 11:36:15.053 1631 1681 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.StateRecord androidx.compose.runtime.snapshots.SnapshotKt.current(androidx.compose.runtime.snapshots.StateRecord) due to JIT inline cache
01-26 11:36:15.055 1631 1681 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.Snapshot androidx.compose.runtime.snapshots.SnapshotKt.currentSnapshot() due to JIT inline cache
01-26 11:36:15.056 1631 1681 I zygote64: Deoptimizing java.lang.Object androidx.compose.runtime.SnapshotThreadLocal.get() due to JIT inline cache
01-26 11:36:15.121 1631 1681 I HomeAssistantSearcher: Service discovery found HA: name: Home, type: _home-assistant._tcp., host: null, port: 0, txtRecord:
01-26 11:36:15.148 1631 1681 I HomeAssistantSearcher: Service resolved: name: Home, type: ._home-assistant._tcp, host: /192.168.0.30, port: 8123, txtRecord: location_name=Home!base_url=http://192.168.1.26:8123
01-26 11:36:15.507 1631 1698 D ProfileInstaller: Installing profile for io.homeassistant.companion.android.minimal
01-26 11:36:16.904 1631 1631 I zygote64: Deoptimizing kotlinx.coroutines.internal.LockFreeLinkedListNode kotlinx.coroutines.internal.LockFreeLinkedListNode.correctPrev(kotlinx.coroutines.internal.OpDescriptor) due to JIT inline cache
01-26 11:36:16.950 1631 1681 I HomeAssistantSearcher: Discovery stopped: _home-assistant._tcp
01-26 11:36:16.956 1631 1631 I zygote64: Deoptimizing java.lang.Object androidx.compose.ui.node.NodeCoordinator.getParentData() due to JIT inline cache
01-26 11:36:16.975 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.MutableState androidx.compose.runtime.SnapshotStateKt.mutableStateOf(java.lang.Object, androidx.compose.runtime.SnapshotMutationPolicy) due to JIT inline cache
01-26 11:36:16.977 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.State androidx.compose.runtime.DynamicProvidableCompositionLocal.provided$runtime_release(java.lang.Object, androidx.compose.runtime.Composer, int) due to JIT inline cache
01-26 11:36:17.108 1631 1699 W cr_ChildProcLH: Create a new ChildConnectionAllocator with package name = com.android.webview, sandboxed = true
01-26 11:36:17.116 1631 1631 I cr_BrowserStartup: Initializing chromium process, singleProcess=false
01-26 11:36:17.340 1631 1631 I android.minimal: type=1400 audit(0.0:1527): avc: denied { read } for name="vmstat" dev="proc" ino=4026531979 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
01-26 11:36:17.340 1631 1631 I android.minimal: type=1400 audit(0.0:1528): avc: denied { open } for path="/proc/vmstat" dev="proc" ino=4026531979 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
01-26 11:36:17.340 1631 1631 I android.minimal: type=1400 audit(0.0:1529): avc: denied { getattr } for path="/proc/vmstat" dev="proc" ino=4026531979 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
01-26 11:36:17.385 1631 1642 I zygote64: Background concurrent copying GC freed 109699(2MB) AllocSpace objects, 6(112KB) LOS objects, 50% free, 7MB/14MB, paused 329us total 288.775ms
01-26 11:36:17.579 1631 1727 W cr_CrashFileManager: /data/user/0/io.homeassistant.companion.android.minimal/cache/WebView/Crash Reports does not exist or is not a directory
01-26 11:36:17.725 1631 1631 I zygote64: Deoptimizing void kotlinx.coroutines.DispatchedTask.run() due to JIT inline cache
01-26 11:36:17.786 1631 1699 I cr_LibraryLoader: Using linker: org.chromium.base.library_loader.ModernLinker
01-26 11:36:17.894 1631 1631 I Choreographer: Skipped 61 frames! The application may be doing too much work on its main thread.
01-26 11:36:17.897 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.StateRecord androidx.compose.runtime.snapshots.SnapshotKt.newOverwritableRecord(androidx.compose.runtime.snapshots.StateRecord, androidx.compose.runtime.snapshots.StateObject) due to JIT inline cache
01-26 11:36:17.931 1631 1631 I zygote64: Deoptimizing void androidx.compose.ui.node.LayoutNodeDrawScope.draw-x_KDEd0$ui_release(androidx.compose.ui.graphics.Canvas, long, androidx.compose.ui.node.NodeCoordinator, androidx.compose.ui.node.DrawModifierNode) due to JIT inline cache
01-26 11:36:18.266 1631 1636 I zygote64: Do full code cache collection, code=507KB, data=359KB
01-26 11:36:18.268 1631 1636 I zygote64: After code cache collection, code=374KB, data=217KB
01-26 11:36:18.734 1631 1745 W VideoCapabilities: Unsupported mime video/flv
01-26 11:36:18.780 1631 1745 I VideoCapabilities: Unsupported profile 4 for video/mp4v-es
01-26 11:36:18.788 1631 1745 W cr_MediaCodecUtil: HW encoder for video/avc is not available on this device.
01-26 11:36:21.815 1631 1631 E AuthenticationFragment: onReceivedError: Status Code: -2 Description: net::ERR_ADDRESS_UNREACHABLE
01-26 11:36:22.092 1631 1662 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
01-26 11:36:22.164 1631 1631 I zygote64: Deoptimizing void androidx.compose.foundation.text.BasicTextKt.BasicText-BpD7jsM(java.lang.String, androidx.compose.ui.Modifier, androidx.compose.ui.text.TextStyle, kotlin.jvm.functions.Function1, int, boolean, int, androidx.compose.runtime.Composer, int, int) due to JIT inline cache
01-26 11:36:22.291 1631 1681 D HomeAssistantSearcher: Service discovery started
01-26 11:36:22.296 1631 1681 I HomeAssistantSearcher: Service discovery found HA: name: Home, type: _home-assistant._tcp., host: null, port: 0, txtRecord:
01-26 11:36:22.298 1631 1681 I HomeAssistantSearcher: Service discovery found HA: name: Home, type: _home-assistant._tcp., host: null, port: 0, txtRecord:
01-26 11:36:22.306 1631 1681 W HomeAssistantSearcher: Failed to resolve service: name: Home, type: _home-assistant._tcp., host: null, port: 0, txtRecord: , error: 3
01-26 11:36:22.321 1631 1681 I HomeAssistantSearcher: Service resolved: name: Home, type: ._home-assistant._tcp, host: /192.168.0.30, port: 8123, txtRecord: location_name=Home!base_url=http://192.168.1.26:8123
01-26 11:36:22.508 1631 1662 I [Gralloc]: Got handle 5 for fd 145
01-26 11:36:22.509 1631 1662 I [Gralloc]: leave, w : 644, h : 254, format : 0x1,internal_format : 0x1, usage : 0xb00. size=666496,pixel_stride=656,byte_stride=2624
01-26 11:36:22.509 1631 1662 I [Gralloc]: leave: prime_fd=145,share_attr_fd=146
01-26 11:36:22.783 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.StateRecord androidx.compose.runtime.snapshots.SnapshotKt.readable(androidx.compose.runtime.snapshots.StateRecord, androidx.compose.runtime.snapshots.StateObject) due to JIT inline cache
01-26 11:36:22.963 1631 1631 I Choreographer: Skipped 32 frames! The application may be doing too much work on its main thread.
01-26 11:36:23.026 1631 1662 I [Gralloc]: Got handle 6 for fd 149
01-26 11:36:23.026 1631 1662 I [Gralloc]: leave, w : 644, h : 254, format : 0x1,internal_format : 0x1, usage : 0xb00. size=666496,pixel_stride=656,byte_stride=2624
01-26 11:36:23.026 1631 1662 I [Gralloc]: leave: prime_fd=149,share_attr_fd=150
01-26 11:36:23.360 1631 1636 I zygote64: Do partial code cache collection, code=494KB, data=342KB
01-26 11:36:23.364 1631 1636 I zygote64: After code cache collection, code=469KB, data=328KB
01-26 11:36:23.364 1631 1636 I zygote64: Increasing code cache capacity to 2MB
01-26 11:36:23.640 1631 1662 I [Gralloc]: Got handle 7 for fd 152
01-26 11:36:23.640 1631 1662 I [Gralloc]: leave, w : 644, h : 254, format : 0x1,internal_format : 0x1, usage : 0xb00. size=666496,pixel_stride=656,byte_stride=2624
01-26 11:36:23.640 1631 1662 I [Gralloc]: leave: prime_fd=152,share_attr_fd=153
01-26 11:36:23.670 1631 1662 I [Gralloc]: Got handle 8 for fd 155
01-26 11:36:23.670 1631 1662 I [Gralloc]: leave, w : 644, h : 254, format : 0x1,internal_format : 0x1, usage : 0xb00. size=666496,pixel_stride=656,byte_stride=2624
01-26 11:36:23.670 1631 1662 I [Gralloc]: leave: prime_fd=155,share_attr_fd=156
01-26 11:36:27.841 1631 1662 W libEGL : EGLNativeWindowType 0x74d4a57010 disconnect failed
01-26 11:36:30.692 1631 1631 I zygote64: Deoptimizing void kotlinx.coroutines.CancellableContinuationImpl.<init>(kotlin.coroutines.Continuation, int) due to JIT inline cache
01-26 11:36:30.693 1631 1631 I zygote64: Deoptimizing boolean kotlinx.coroutines.AbstractCoroutine.isActive() due to JIT inline cache
01-26 11:36:30.704 1631 1631 I zygote64: Deoptimizing boolean kotlinx.coroutines.JobSupport.isActive() due to JIT inline cache
01-26 11:36:30.708 1631 1631 I zygote64: Deoptimizing kotlinx.coroutines.internal.LockFreeLinkedListNode kotlinx.coroutines.internal.LockFreeLinkedListNode.correctPrev(kotlinx.coroutines.internal.OpDescriptor) due to JIT inline cache
01-26 11:36:30.734 1631 1681 I HomeAssistantSearcher: Discovery stopped: _home-assistant._tcp
01-26 11:36:30.740 1631 1631 I zygote64: Deoptimizing java.lang.Object androidx.compose.ui.node.NodeCoordinator.getParentData() due to JIT inline cache
01-26 11:36:30.786 1631 1631 I zygote64: Deoptimizing androidx.compose.ui.Modifier androidx.compose.ui.ComposedModifierKt.composed(androidx.compose.ui.Modifier, kotlin.jvm.functions.Function1, kotlin.jvm.functions.Function3) due to JIT inline cache
01-26 11:36:31.194 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.StateRecord androidx.compose.runtime.snapshots.SnapshotKt.used(androidx.compose.runtime.snapshots.StateObject) due to JIT inline cache
01-26 11:36:31.194 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.snapshots.StateRecord androidx.compose.runtime.snapshots.SnapshotKt.newOverwritableRecord(androidx.compose.runtime.snapshots.StateRecord, androidx.compose.runtime.snapshots.StateObject) due to JIT inline cache
01-26 11:36:31.202 1631 1631 I zygote64: Deoptimizing void androidx.compose.runtime.snapshots.SnapshotStateObserver$applyObserver$1$2.invoke() due to JIT inline cache
01-26 11:36:31.243 1631 1636 I zygote64: Compiler allocated 4MB to compile void androidx.compose.foundation.layout.SpacerKt.Spacer(androidx.compose.ui.Modifier, androidx.compose.runtime.Composer, int)
01-26 11:36:31.269 1631 1631 I Choreographer: Skipped 33 frames! The application may be doing too much work on its main thread.
01-26 11:36:31.270 1631 1631 I zygote64: Deoptimizing void androidx.compose.runtime.BroadcastFrameClock$FrameAwaiter.resume(long) due to JIT inline cache
01-26 11:36:31.406 1631 1631 I zygote64: Deoptimizing void androidx.compose.ui.node.LayoutNodeLayoutDelegate$MeasurePassDelegate.forEachChildAlignmentLinesOwner(kotlin.jvm.functions.Function1) due to JIT inline cache
01-26 11:36:31.500 1631 1631 I zygote64: Deoptimizing void androidx.compose.runtime.snapshots.SnapshotStateObserver$ObservedScopeMap.notifyInvalidatedScopes() due to JIT inline cache
01-26 11:36:32.499 1631 1636 I zygote64: Compiler allocated 5MB to compile void androidx.compose.foundation.text.CoreTextFieldKt.CoreTextField(androidx.compose.ui.text.input.TextFieldValue, kotlin.jvm.functions.Function1, androidx.compose.ui.Modifier, androidx.compose.ui.text.TextStyle, androidx.compose.ui.text.input.VisualTransformation, kotlin.jvm.functions.Function1, androidx.compose.foundation.interaction.MutableInteractionSource, androidx.compose.ui.graphics.Brush, boolean, int, androidx.compose.ui.text.input.ImeOptions, androidx.compose.foundation.text.KeyboardActions, boolean, boolean, kotlin.jvm.functions.Function3, androidx.compose.runtime.Composer, int, int, int)
01-26 11:36:32.683 1631 1636 I zygote64: Compiler allocated 5MB to compile void androidx.compose.material.TextFieldKt.TextFieldLayout(androidx.compose.ui.Modifier, kotlin.jvm.functions.Function2, kotlin.jvm.functions.Function2, kotlin.jvm.functions.Function3, kotlin.jvm.functions.Function2, kotlin.jvm.functions.Function2, boolean, float, androidx.compose.foundation.layout.PaddingValues, androidx.compose.runtime.Composer, int)
01-26 11:36:32.842 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:32.852 1631 1631 I zygote64: Deoptimizing java.lang.Object kotlinx.coroutines.channels.AbstractSendChannel.offerInternal(java.lang.Object) due to JIT inline cache
01-26 11:36:33.038 1631 1631 I zygote64: Deoptimizing java.lang.Object androidx.compose.animation.core.InfiniteAnimationPolicyKt.withInfiniteAnimationFrameNanos(kotlin.jvm.functions.Function1, kotlin.coroutines.Continuation) due to JIT inline cache
01-26 11:36:33.160 1631 1631 I zygote64: Deoptimizing androidx.compose.runtime.external.kotlinx.collections.immutable.implementations.immutableMap.TrieNode androidx.compose.runtime.external.kotlinx.collections.immutable.implementations.immutableMap.TrieNode.mutablePutAllFromOtherNodeCell(androidx.compose.runtime.external.kotlinx.collections.immutable.implementations.immutableMap.TrieNode, int, int, androidx.compose.runtime.external.kotlinx.collections.immutable.internal.DeltaCounter, androidx.compose.runtime.external.kotlinx.collections.immutable.implementations.immutableMap.PersistentHashMapBuilder) due to JIT inline cache
01-26 11:36:33.226 1631 1662 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
01-26 11:36:33.251 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:33.408 1631 1662 I [Gralloc]: Got handle 5 for fd 146
01-26 11:36:33.408 1631 1662 I [Gralloc]: leave, w : 53, h : 57, format : 0x1,internal_format : 0x1, usage : 0xb00. size=14592,pixel_stride=64,byte_stride=256
01-26 11:36:33.408 1631 1662 I [Gralloc]: leave: prime_fd=146,share_attr_fd=147
01-26 11:36:33.474 1631 1662 I [Gralloc]: Got handle 6 for fd 149
01-26 11:36:33.474 1631 1662 I [Gralloc]: leave, w : 53, h : 57, format : 0x1,internal_format : 0x1, usage : 0xb00. size=14592,pixel_stride=64,byte_stride=256
01-26 11:36:33.474 1631 1662 I [Gralloc]: leave: prime_fd=149,share_attr_fd=150
01-26 11:36:33.517 1631 1631 W RecordingIC: requestCursorUpdates is not supported
01-26 11:36:35.097 1631 1631 I zygote64: Deoptimizing void androidx.compose.ui.node.BackwardsCompatNode.updateModifierLocalProvider(androidx.compose.ui.modifier.ModifierLocalProvider) due to JIT inline cache
01-26 11:36:35.195 1631 1662 I [Gralloc]: Got handle 7 for fd 152
01-26 11:36:35.195 1631 1662 I [Gralloc]: leave, w : 53, h : 57, format : 0x1,internal_format : 0x1, usage : 0xb00. size=14592,pixel_stride=64,byte_stride=256
01-26 11:36:35.195 1631 1662 I [Gralloc]: leave: prime_fd=152,share_attr_fd=153
01-26 11:36:35.676 1631 1636 I zygote64: Do full code cache collection, code=1013KB, data=684KB
01-26 11:36:35.679 1631 1636 I zygote64: After code cache collection, code=912KB, data=540KB
01-26 11:36:36.272 1631 1662 I [Gralloc]: Got handle 8 for fd 155
01-26 11:36:36.272 1631 1662 I [Gralloc]: leave, w : 53, h : 57, format : 0x1,internal_format : 0x1, usage : 0xb00. size=14592,pixel_stride=64,byte_stride=256
01-26 11:36:36.272 1631 1662 I [Gralloc]: leave: prime_fd=155,share_attr_fd=156
01-26 11:36:37.094 1631 1631 I zygote64: Deoptimizing boolean kotlinx.coroutines.JobSupport.isActive() due to JIT inline cache
01-26 11:36:38.200 1631 1642 I zygote64: Background concurrent copying GC freed 209140(5MB) AllocSpace objects, 17(796KB) LOS objects, 49% free, 7MB/15MB, paused 128us total 127.598ms
01-26 11:36:38.429 1631 1631 I zygote64: Deoptimizing boolean androidx.compose.runtime.external.kotlinx.collections.immutable.implementations.immutableMap.PersistentHashMap.containsKey(java.lang.Object) due to JIT inline cache
01-26 11:36:38.505 1631 1631 I zygote64: Deoptimizing boolean androidx.compose.ui.node.NodeCoordinator.isAttached() due to JIT inline cache
01-26 11:36:38.521 1631 1662 W libEGL : EGLNativeWindowType 0x74d4b22010 disconnect failed
01-26 11:36:38.577 1631 1631 I zygote64: Deoptimizing boolean kotlinx.coroutines.AbstractCoroutine.isActive() due to JIT inline cache
01-26 11:36:39.263 1631 1636 I zygote64: Do partial code cache collection, code=1009KB, data=652KB
01-26 11:36:39.264 1631 1636 I zygote64: After code cache collection, code=1008KB, data=652KB
01-26 11:36:39.264 1631 1636 I zygote64: Increasing code cache capacity to 3MB
01-26 11:36:42.358 1631 1685 I zygote64: Deoptimizing void kotlinx.coroutines.DispatchedTask.run() due to JIT inline cache
01-26 11:36:42.358 1631 1685 D WebSockManager: Done listening to Websocket
01-26 11:36:42.359 1631 1685 I zygote64: Deoptimizing java.lang.Object kotlinx.coroutines.JobSupport.finalizeFinishingState(kotlinx.coroutines.JobSupport$Finishing, java.lang.Object) due to JIT inline cache
01-26 11:36:42.366 1631 1646 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=fec4a107-95f4-41a2-85e5-1f045f554581, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
01-26 11:36:42.379 1631 1631 I WM-SystemFgDispatcher: Stopping foreground service
01-26 11:36:42.524 1631 1636 I zygote64: Compiler allocated 4MB to compile void androidx.compose.foundation.text.CoreTextFieldKt$CoreTextField$5$1$1.invoke(androidx.compose.runtime.Composer, int)
01-26 11:36:46.011 1631 1631 I zygote64: Deoptimizing androidx.compose.ui.Modifier androidx.compose.ui.semantics.SemanticsModifierKt.semantics(androidx.compose.ui.Modifier, boolean, kotlin.jvm.functions.Function1) due to JIT inline cache
01-26 11:36:46.041 1631 1631 I zygote64: Deoptimizing kotlin.coroutines.CoroutineContext kotlinx.coroutines.CoroutineContextKt.newCoroutineContext(kotlinx.coroutines.CoroutineScope, kotlin.coroutines.CoroutineContext) due to JIT inline cache
01-26 11:36:46.042 1631 1631 I zygote64: Deoptimizing void kotlinx.coroutines.DispatchedTask.run() due to JIT inline cache
01-26 11:36:46.064 1631 1699 W cr_ChildProcLH: Create a new ChildConnectionAllocator with package name = com.android.webview, sandboxed = true
01-26 11:36:46.073 1631 1631 I zygote64: Deoptimizing void androidx.compose.ui.node.BackwardsCompatNode.initializeModifier(boolean) due to JIT inline cache
01-26 11:36:46.119 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:46.122 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:46.123 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:46.124 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:46.124 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:46.125 1631 1631 D Compose Focus: Owner FocusChanged(true)
01-26 11:36:46.127 1631 1631 D Compose Focus: Owner FocusChanged(false)
01-26 11:36:46.131 1631 1631 I zygote64: Deoptimizing void androidx.compose.ui.focus.FocusModifier.onModifierLocalsUpdated(androidx.compose.ui.modifier.ModifierLocalReadScope) due to JIT inline cache
01-26 11:36:46.190 1631 1631 I zygote64: Deoptimizing boolean kotlinx.coroutines.CoroutineScopeKt.isActive(kotlinx.coroutines.CoroutineScope) due to JIT inline cache
01-26 11:36:46.593 1631 1631 I chromium: [INFO:CONSOLE(1)] "The key "viewport-fit" is not recognized and ignored.", source: http://192.168.0.30:8123/auth/authorize?response_type=code&client_id=https://home-assistant.io/android&redirect_uri=homeassistant://auth-callback (1)
01-26 11:36:46.633 1631 1631 I chromium: [INFO:CONSOLE(1)] "Uncaught SyntaxError: Unexpected token import", source: http://192.168.0.30:8123/auth/authorize?response_type=code&client_id=https://home-assistant.io/android&redirect_uri=homeassistant://auth-callback (1)
