Hello to all.
Today, suddenly, the Home Assistant app on the iPhone doesn’t load anything and my Google Mini no longer recognizes the various home automation devices.
The DuckDNS log says:
Retrieving subdomain and token from the environment variables
log will be output to docker log
Your IP was updated at Mon Apr 5 18:47:50 CEST 2021
[cont-init.d] 40-config: exited 0.
[cont-init.d] 99-custom-files: executing …
[custom-init] no custom files found exiting …
[cont-init.d] 99-custom-files: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Something went wrong, please check your settings Mon Apr 5 18:50:01 CEST 2021
Something went wrong, please check your settings Mon Apr 5 18:55:02 CEST 2021
Something went wrong, please check your settings Mon Apr 5 19:00:01 CEST 2021
Something went wrong, please check your settings Mon Apr 5 19:05:02 CEST 2021
Also in the Caddy log I have an error:
err_trace “:” reverseproxy.statusError (reverseproxy.go: 783) "
What may have happened?
Can you please help me?
Thank you.
The Home Assistant LOG is full of errors:
2021-04-05 19:33:33 WARNING (MainThread) [homeassistant.loader] You are using a custom integration fritzbox_tools which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-05 19:33:33 WARNING (MainThread) [homeassistant.loader] You are using a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-05 19:33:33 WARNING (MainThread) [homeassistant.loader] You are using a custom integration plex_assistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-05 19:33:33 WARNING (MainThread) [homeassistant.loader] You are using a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-05 19:34:21 ERROR (MainThread) [homeassistant.components.transmission] Connecting to the Transmission client 192.168.178.49 failed
2021-04-05 19:34:21 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Transmission’ for transmission integration not ready yet. Retrying in the background
2021-04-05 19:34:25 ERROR (MainThread) [homeassistant.components.switch] Platform fritzbox_tools does not generate unique IDs. ID 989BCBA6A016-switch.fritzbox_7530_portforward_caddy is already used by switch.fritzbox_7530_portforward_caddy - ignoring switch.fritzbox_7530_portforward_caddy
2021-04-05 19:34:26 ERROR (MainThread) [homeassistant.components.transmission] Connecting to the Transmission client 192.168.178.49 failed
2021-04-05 19:34:32 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘FRITZ! Box 7530’ for upnp integration not ready yet. Retrying in the background
2021-04-05 19:34:32 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘InternetGatewayDeviceV2 - FRITZ! Box 7530’ for upnp integration not ready yet. Retrying in the background
2021-04-05 19:34:32 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘N600 Wireless Dual Band Gigabit VDSL2 Modem Router TD-W9980’ for upnp integration not ready yet. Retrying in the background
2021-04-05 19:34:33 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:requestSync failed: 404
2021-04-05 19:34:35 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
Luke, [05.04.21 19:53]
2021-04-05 19:34:36 ERROR (MainThread) [homeassistant.components.transmission] Connecting to the Transmission client 192.168.178.49 failed
2021-04-05 19:34:47 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-04-05 19:34:54 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-04-05 19:34:56 ERROR (MainThread) [homeassistant.components.transmission] Connecting to the Transmission client 192.168.178.49 failed
2021-04-05 19:35:05 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
