Hi. Just moved into an apartment with a lot of GY 6,35 lights. Does there exist any GY 6,35 bulbs that are compatible with Home assistant? Web search gives no result.
They are probably too smal to be able to make smart.
I think you need to connect something on the wires instead.
Thank you for the response! After some more search I found these (see link below). It’s in norwegian, but it says zigbee compatible. I even contacted them and they confirmed it.
I’m pretty new to Home assistant, so this might be a dumb question. Is there hope for a semi technical person to add unlisted devices or is this for the experts only?
