HA Compatible Smart Speaker (No Home, Alexa, ... devices)?
I’m wondering what smart speakers people are using. I kind of not want Google to record everything in my house, nor Amazon etc.
Basically what I would like is a speaker which can play Text-to-speech stuff, e.g. announcing the weather in the morning, and other stuff like that.
I don’t need HQ audio playback either, i.e. not interested in premium Sonos devices.
Any tips?
I use rasperry pis with snapcast and mopidy connected to the speakers. Everything local, TTS, multiroom audio from different sources or synced play.
As a test I dusted off an old rpi1 I used as a kodi box a loooong time ago, hooked up some Jabra speaker and WiFi adapter (no onboard wifi on the pi1) and miraculously it actually pinged back when I tried its mDNS name :smiley: only problem is I only allow ssh PKI logins and I don’t have any device that still has access keys.
So, my question is, what should I flash on the sdcard (it’s an 8GB one)? What linux distro is well suited for the job described in earlier posts?
Dietpi. …
I use piCorePlayer with Squeezelite in each of my rooms:
https://www.picoreplayer.org/
They are playing music and can also be used for TTS.
The server is installed on my Synology NAS but you could also install it on a raspberry.
Check out this squeezelite project https://forums.slimdevices.com/showthread.php?111328-ANNOUNCE-the-SqueezeAMP-next-generation-squeezeboxen-amplifier-receiver.
This board includes 2*3watt amps as well
https://a.aliexpress.com/_d7gNoSW
Burningstone, can you make a tutorial in how to archive that?
I saw the next guides, but don’t have the TTS capability. You use Alexa for TTS?
