I’m running HA OS on a raspberry pi 3b+ with a 32gig sd card. It has been running fine for the last several months, but suddenly it has starred crashing out right. It’s totally random as to when it happens too. I have zero idea at the cause, so I’ll reaching out for help.
There are some issues with flooding of the websockets which might occur due to stale browser windows.
Editing the GUI frontend in the internal editor seems to make it worse, especially if you edit a name for a sensor in a line that already is working. The GUI will then try to lookup the “new” sensor name for each letters typed or deleted.
Could be.
Usually you need to find the stale browser window and close it, which stops the crashing, but you need a restart of the HA host (not just HA) to free the ressources that was allocated and not freed correctly in the crashes.
