I have been searching for a HA controlled socket (UK layout) but with a dimmer function to control a light. Has anyone used/found one?
Not used one but this looks like what you’re after ?
thanks! yes that is wht I am looking for or an in wire solution. at £37 seems a bit expensive.
You could use a Shelly Dimmer or similar if you’re willing to cut the lamp cord and put the Module in some sort of enclosure.
Or use a smart bulb, they are a bit cheaper.
I have realised I made a mistake and was using a variable speed controller… I thought I used a light dimmer, but it was for a fan…
