I see the update available. I have tried installing it many times. I also rebooted the system. But after install HA reboots, and says it still at 2024.1.3… and says 2024.1.4 is available for installation.
Yes, I had the same problem last night. I tried again a few minutes ago and it is still happening.
I’m not sure if this is related, but I found it in home-assistant.log.1:
2024-01-20 07:36:53.905 ERROR (MainThread) [root] Uncaught exception
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 221, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 188, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 147, in async_setup_hass
config_dict = await conf_util.async_hass_config_yaml(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 501, in async_hass_config_yaml
await merge_packages_config(hass, config, core_config.get(CONF_PACKAGES, {}))
File "/usr/src/homeassistant/homeassistant/config.py", line 1029, in merge_packages_config
PACKAGES_CONFIG_SCHEMA(packages)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 588, in verify
return cast(dict, schema(value))
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected a dictionary for dictionary value @ data['alert']
2024-01-20 10:50:03.592 ERROR (MainThread) [root] Uncaught exception
sys.exit(main())
voluptuous.error.MultipleInvalid: expected a dictionary for dictionary value @ data['conversation']
Same here. [CAUSE : An empty homeassistant.yaml file…]
2024-01-20 14:48:44.307 ERROR (MainThread) [root] Uncaught exception
sys.exit(main())
voluptuous.error.MultipleInvalid: expected a dictionary for dictionary value @ data['homeassistant']
Thank you. I had an alarm.yaml file in my packages directory that had all of the lines commented out because they weren’t being used since moving to Alarmo. I renamed the file to alarm.yaml.unused and all is good again.
edit: removed (empty) scenes.yaml and scripts.yaml, which resulted in reboot in recovery mode. Recreated the files and now after reboot everything was ok (2024.1.3 → 2024.1.5)
I am also unable to update past 2024.1.5 but errors look different.
2024-02-02 12:52:19.747 ERROR (MainThread) [root] Uncaught exception
sys.exit(main())
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 684, in run_until_complete
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 203, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 319, in async_from_config_dict
await async_load_base_functionality(hass)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 296, in async_load_base_functionality
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1354, in async_initialize
entries[entry_id] = config_entry
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1148, in __setitem__
self._domain_unique_id_index.setdefault(entry.domain, {})[
TypeError: unhashable type: 'list'
There are no blank yaml files, I can’t seem to find this list that’s creating an error.
@tybo611 Did you get this fixed as I am having the same issue?
my rollback log looks like this
2024-02-07 16:28:36.019 ERROR (MainThread) [root] Uncaught exception
sys.exit(main())
Yes. My error ended up being a custom component that wasn’t maintained anymore since core had picked up the integration. In my case it was schlage encode wifi. Took a little to figure it out but once removed upgrade went fine.
I found it by taking a full backup then systematically deleting integrations and trying the update. Just kept going until it worked, rolled back to the backup, deleted the problem and upgraded.
