With the beta of this month the integration stopped working it is not connecting… to the device anymore. When I restore the backup of the last version it works again.
The device is the Victron Smart Battery Sense
I have the latest version of this integration
--> 0.1.1
## Version of the custom_component
## Configuration
```yaml
Logger: homeassistant.config_entries
Source: config_entries.py:594
First occurred: 10:55:51 AM (1 occurrences)
Last logged: 10:55:51 AM
Error setting up entry Victronsmartbattery for victron_ble
File "/usr/src/homeassistant/homeassistant/loader.py", line 1249, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1281, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 128, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/init.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "", line 1387, in _gcd_import
File "", line 1360, in _find_and_load
File "", line 1331, in _find_and_load_unlocked
File "", line 935, in _load_unlocked
File "", line 995, in exec_module
File "", line 488, in _call_with_frames_removed
File "/config/custom_components/victron_ble/sensor.py", line 198, in
PassiveBluetoothDataProcessor[Optional[Union[float, int]]]
File "/usr/local/lib/python3.12/typing.py", line 384, in inner
return func(*args, **kwds)
File "/usr/local/lib/python3.12/typing.py", line 1066, in _generic_class_getitem
_check_generic(cls, params, len(cls.parameters))
File "/usr/local/lib/python3.12/site-packages/typing_extensions.py", line 2941, in _check_generic
raise TypeError(f"Too {'many' if alen > elen else 'few'} arguments"
TypeError: Too few arguments for <class 'homeassistant.components.bluetooth.passive_update_processor.PassiveBluetoothDataProcessor'>; actual 1, expected at least 2
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/victron_ble/init.py", line 36, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2031, in async_forward_entry_setups
await integration.async_get_platforms(platforms)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1162, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1150, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1075, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1269, in _load_platform
raise ImportError(
ImportError: Exception importing custom_components.victron_ble.sensor
