HA core 2026.6
HA core 2026.6 caused X-Sense integration to stop working.
This one isn't a config problem on your side, it's a known break that's already fixed. The newer core tightened its "blocking call inside the event loop" check, and older X-Sense builds tripped it: the integration was creating its MQTT TLS context with ssl.create_default_context(), which loads the CA certs from disk (blocking I/O) during setup. Older cores only warned; the newer guard aborts it, so the integration fails to start.
The fix shipped shortly after 1.2.1. Update the X-Sense integration in HACS to the latest release (currently v1.2.6.3) and restart Home Assistant. The new code builds the TLS context in HA's executor instead of the event loop. If you're still on 1.2.1, that's the version with the bug.
If after updating you get a timeout ("Timed out connecting to X-Sense") instead of the blocking-call error, that's a separate, still-open issue (GH #190), not the core regression, so report there if it persists.
Details and the maintainer's fix note are in GH issue #188 on Jarnsen/ha-xsense-component_test.
Thank you. It's working now.
Awesome! You're welcome.
@drs good that your problem is solved!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
@drs: you marked the wrong post as the solution...
