After installing the latest version of HA 2022.9.4 on my raspi it is not starting up fully anymore. I tried to solve it for some days now, going back to 2022.8 and even 2022.6 without success. I also tried te disable some integrations. Now I’m in some way out of ideas.
The log-file is
2022-09-16 03:19:30.925 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //home/homeassistant/.homeassistant/home-assistant_v2.db was shutdown cleanly
2022-09-16 03:19:39.678 WARNING (MainThread) [homeassistant.components.mqtt] The 'birth_message' option near /home/homeassistant/.homeassistant/configuration.yaml:13 is deprecated, please remove it from your configuration
2022-09-16 03:19:39.684 WARNING (MainThread) [homeassistant.components.mqtt] The 'broker' option near /home/homeassistant/.homeassistant/configuration.yaml:13 is deprecated, please remove it from your configuration
2022-09-16 03:19:39.685 WARNING (MainThread) [homeassistant.components.mqtt] The 'discovery' option near /home/homeassistant/.homeassistant/configuration.yaml:13 is deprecated, please remove it from your configuration
2022-09-16 03:19:39.686 WARNING (MainThread) [homeassistant.components.mqtt] The 'will_message' option near /home/homeassistant/.homeassistant/configuration.yaml:13 is deprecated, please remove it from your configuration
2022-09-16 03:19:39.847 WARNING (MainThread) [pyotgw.commandprocessor] Unknown message in command queue: SC: 03:19/5
2022-09-16 03:19:39.852 WARNING (MainThread) [pyotgw.commandprocessor] Command PS failed with SC: 03:19/5, retrying...
2022-09-16 03:19:40.383 WARNING (MainThread) [pyotgw.commandprocessor] Unknown message in command queue: PS: 0
2022-09-16 03:19:40.385 WARNING (MainThread) [pyotgw.commandprocessor] Command PR failed with PS: 0, retrying...
2022-09-16 03:19:41.570 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 10.0.0.27:5555. TcpTimeoutException: Connecting to 10.0.0.27:5555 timed out (1.0 seconds)
2022-09-16 03:19:41.573 WARNING (MainThread) [homeassistant.config_entries] Config entry 'BernisLeinwand' for androidtv integration not ready yet: Could not connect to Android TV / Fire TV device at 10.0.0.27:5555 using Python ADB implementation with adbkey='/home/homeassistant/.homeassistant/.storage/androidtv_adbkey'; Retrying in background
2022-09-16 03:19:43.535 WARNING (MainThread) [homeassistant.components.home_connect] The 'home_connect' option near /home/homeassistant/.homeassistant/configuration.yaml:1 is deprecated, please remove it from your configuration
2022-09-16 03:19:43.541 WARNING (MainThread) [homeassistant.components.home_connect] Configuration of Home Connect integration in YAML is deprecated and will be removed in a future release; Your existing OAuth Application Credentials have been imported into the UI automatically and can be safely removed from your configuration.yaml file
2022-09-16 03:19:49.422 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback SerialTransport._call_connection_lost(None)
File "/usr/lib/python3.9/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/srv/homeassistant/lib/python3.9/site-packages/serial_asyncio/__init__.py", line 414, in _call_connection_lost
self._serial.close()
File "/srv/homeassistant/lib/python3.9/site-packages/serial/urlhandler/protocol_socket.py", line 104, in close
time.sleep(0.3)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/util/async_.py", line 180, in protected_loop_func
check_loop(func, strict=strict)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/util/async_.py", line 141, in check_loop
raise RuntimeError(
RuntimeError: Detected blocking call to sleep inside the event loop. Use `await hass.async_add_executor_job()`; This is causing stability issues. Please report issue
2022-09-16 03:19:49.467 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Zentralheizung' for opentherm_gw integration not ready yet: Could not connect to gateway at socket://10.0.0.26:25238: ; Retrying in background
2022-09-16 03:19:50.838 WARNING (MainThread) [homeassistant.config_entries] Config entry 'roborock.vacuum' for xiaomi_miio integration not ready yet; Retrying in background
2022-09-16 03:19:50.839 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Robi' for xiaomi_miio integration not ready yet; Retrying in background
2022-09-16 03:20:04.794 WARNING (MainThread) [homeassistant.components.kodi.media_player] Unable to connect to Kodi via websocket
2022-09-16 03:20:05.796 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 10.0.0.27:5555. TcpTimeoutException: Connecting to 10.0.0.27:5555 timed out (1.0 seconds)
2022-09-16 03:20:15.958 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:requestSync failed: 500
2022-09-16 03:20:16.813 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 10.0.0.27:5555. TcpTimeoutException: Connecting to 10.0.0.27:5555 timed out (1.0 seconds)
2022-09-16 03:20:37.823 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 10.0.0.27:5555. TcpTimeoutException: Connecting to 10.0.0.27:5555 timed out (1.0 seconds)
2022-09-16 03:23:07.484 ERROR (MainThread) [homeassistant.components.androidtv.media_player] Failed to execute an ADB command. ADB connection re-establishing attempt in the next update. Error: Reading from 10.0.0.27:5555 timed out (9.0 seconds)
2022-09-16 03:23:09.484 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 10.0.0.27:5555. TcpTimeoutException: Connecting to 10.0.0.27:5555 timed out (1.0 seconds)
2022-09-16 03:23:15.709 WARNING (Thread-6) [pychromecast.socket_client] [BernisLeinwand(10.0.0.27):8009] Heartbeat timeout, resetting connection
2022-09-16 03:23:45.739 ERROR (Thread-6) [pychromecast.socket_client] [BernisLeinwand(10.0.0.27):8009] Failed to connect to service ServiceInfo(type='host', data=('10.0.0.27', 8009)), retrying in 5.0s
On the UI I see the loading screen with
Unable to connect to Home Assistant.
Retrying in -643 seconds...
For me it seams something in the core of homeassistant is stuck very badly. I don’t know how to disable all integrations and enable the one by one to find the problem.
Unfortunately I did also some other upgrades at the same time, so I don’t know if the upgrade of the home assistant is the reason for the problem.
Any help how to find the problem would be very helpful.
