HA Core (Overkiz) - Cozytouch Sauter
Hello everyone,
I am planning to install Sauter radiators soon, and would like to know if you were able to connect them to Home Assistant via the Sauter Cozytouch?
If yes, under overkiz (integrated into core HA), there is no “Cozytouch Sauter” item, is it really under the “Cozytouch Atlantic” item that you must connect with your Sauter credentials?
Thank you in advance for your help,
Good day,
THis is an old post, however for those who are searching an answer: yes, Overkiz is working for Cozytouch Sauter, if you are using the bridge Cozytouch.
You will have to select the server “Thermor Cozytouch”, then your email and password and that’s all.
