Hi all,
I updated my HA core installation at latest version.
Now I have a problem only by android app and with 4G connection (the app works fine when connected to the lan). If I’m connecting by a pc outside the lan, there aren’t problems…
When I start the app, the main page is empty but energy page, map page… works (the problem is only in the main page)…
This is the error log:
Logger: frontend.js.latest.202209072
Source: components/system_log/__init__.py:227
First occurred: 29 settembre 2022 18:57:31 (4 occurrences)
Last logged: 14:36:21
https://xxx.duckdns.org:8123/frontend_latest/08219b6a.js:362:5549 Uncaught TypeError: Cannot read properties of undefined (reading '0')
https://xxx.duckdns.org:8123/frontend_latest/08219b6a.js:362:5549 Uncaught TypeError: Cannot read properties of undefined (reading '1')
If I close and open the app several times, sometimes works…
ever since yesterday i am having the same problem. Using duckdns to reach my HA externally is no longer possible. The only thing i find in the log is the same error message as posted by OP.
could you give a bit more details on how you fixed the issue? i am not entirely sure i undestand.
i have the external access set up w nginx proxy and maria db.
thank you
:edit
think i fixed it ,re-read your post and changed to another dyndns account. now it works again. stupid duckdns
I removed duckddns and it works… so has HA a problem with DUCKDDNS because the problem starts with the september update… Is possible notify the problem?
