I’m running HA Core in a docker container on Unraid. Inexplicably today my HA docker won’t start, and I’m getting the following in the logs. Any idea what has happened and how to recover?
[02:48:06] INFO: Home Assistant Core finish process exit code 1
[02:48:06] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
[02:48:06] INFO: Home Assistant Core finish process exit code 256
[02:48:06] INFO: Home Assistant Core finish process received signal 15
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2022-08-30 20:25:50.249 ERROR (SyncWorker_0) [homeassistant.util.json] Could not parse JSON content: /config/.storage/core.config_entries
File "/usr/src/homeassistant/homeassistant/util/json.py", line 39, in load_json
return orjson.loads(fdesc.read()) # type: ignore[no-any-return]
orjson.JSONDecodeError: input length is 0: line 1 column 2 (char 1)
2022-08-30 20:25:50.251 ERROR (MainThread) [root] Uncaught exception
File "/usr/local/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 203, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 191, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 119, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 646, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 101, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 143, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 224, in async_from_config_dict
await hass.config_entries.async_initialize()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 965, in async_initialize
config = await storage.async_migrator(
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 44, in async_migrator
if (store_data := await store.async_load()) is not None:
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 116, in async_load
return await self._load_task
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 125, in _async_load
return await self._async_load_data()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 143, in _async_load_data
data = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/util/json.py", line 45, in load_json
raise HomeAssistantError(error) from error
homeassistant.exceptions.HomeAssistantError: input length is 0: line 1 column 2 (char 1)
[03:25:50] INFO: Home Assistant Core finish process exit code 1
[03:25:50] INFO: Home Assistant Core service shutdown
[03:25:50] INFO: Home Assistant Core finish process exit code 256
[03:25:50] INFO: Home Assistant Core finish process received signal 15
