Hi All!
After the last Core update (and Server update, did them together) I can no longer intialize or update my ESP32 WROOM-32D Boards? I could do this fine before the upgrade…
However,
ESP32 WROOM-32 Boards are not a problem, business as usual.
I used to just choose ESP32 for both in the dialog when choosing the setup.
The error i get is:
Blockquote
ERROR Running command failed: Failed to connect to ESP32: Wrong boot mode detected (0x13)! The chip needs to be in download mode.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 460800 --port /dev/ttyUSB0 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/build/breakout/.pioenvs/breakout/firmware.bin 0x1000 /data/build/breakout/.pioenvs/breakout/bootloader.bin 0x8000 /data/build/breakout/.pioenvs/breakout/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
esptool.py v4.7.0
Serial port /dev/ttyUSB0
Connecting…
ERROR Running command failed: Invalid head of packet (0x01): Possible serial noise or corruption.
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 115200 --port /dev/ttyUSB0 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/build/breakout/.pioenvs/breakout/firmware.bin 0x1000 /data/build/breakout/.pioenvs/breakout/bootloader.bin 0x8000 /data/build/breakout/.pioenvs/breakout/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
Blockquote
These are the newer boards that won’t work
And these ones work
