Thank you @badstraw.
I am running HA in a Docker on Ubuntu on a NUC and used your config entry to get a perfect result.
Beers are on me!
I am running HA in a Docker on Ubuntu on a HP minipc, i tried the parameters written in this trhead, but it doesn’t work.
I installed
sudo apt install lm-sensors
and I can see the temperature with command sensors
what parameters could i use to create a temperature sensor?
I’m using Home Assistant Supervised on a Ubuntu Server machine and this worked perfectly!
Thank you!
